chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
mdgm-ntgr
Apr 15, 2014NETGEAR Employee Retired
I would suggest that if you can't access the Dashboard you should check the fullness of the 4GB OS partition before attempting to update via SSH.
You could do e.g.
You could do e.g.
# df -h
