chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
mdgm-ntgr
Aug 11, 2014NETGEAR Employee Retired
An OS Re-install will re-install OS6. The update processed involved replacing the files on the internal flash. The files on the internal flash are used for OS Re-installs etc.
Do you have SSH access?
If so, what is the output of the following?:
# tail -n 20 /var/log/apache2/error.log
# systemctl status apache2
