chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
Litoz
Sep 21, 2014Aspirant
Hello Forum,
So I've upgraded my Ultra 2 to the Os 6.1.8 and then through the web UI upgraded to 6.1.9. Thing here is that I've read that initially there was some loud fan issues, my problem goes the other way arround according to the UI the fan speed is below 800rpm and CPU temp are 58 C+. Is this way too high?
Can I use some tricks to set fan speed not to drop below....100rpm? (I'm aware of the bearing wear off this might have if I abuse off it)
Some images of my status
All help apreciatted
