chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
mdgm-ntgr
Apr 23, 2015NETGEAR Employee Retired
I would update to 6.2.3.
Whether you should use bit-rot protection or not depends on your use case.
