chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
Aiddy
Sep 04, 2015Aspirant
Hi,
Sorry to revive an old thread, I have just taken the plunge and updated my Pro Pioneer Edition using the 'PREP4TOR6_0.1-x86.bin' & 'R4toR6_latest.bin' files downloaded on the 27th August. Nearly everything is working perfectly but I do have 1 question & 1 problem.
Question, by NAS shows it's running 6.3.5 - Is that correct? As the Pro Pioneer is an x86 based machine I would have expected 6.2.4 at best?
Problem, I am unable to logon to Vault. I keep getting a 'Vault Login Failed' error. (everything works if I logon via browser - so my account is ok)
I know there has been a recent (20th July 2015) update to Vault to v2.9.23 which I had carried out prior to upgrading (i.e. whlst on FrontView 4.x) so am wondering if this could be the issue - however, I have tried installing the package from http://www.readynasvault.com/update/ but it keeps failing to install.
Can you help?
cheers,
Adrian
- SandsharkSep 07, 2015Sensei
All of my legacy systems are running 6.2.4, which reports to be the latest available version. So I don't know how you could actually be running 6.3.5. Where is this reported, in Frontview, RAIDar, or both?
- StephenBSep 07, 2015Guru - Experienced User
Note this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-upgrade-question-on-legacy-Pro-6/m-p/979096#U979096
6.3.5 (beta rc2) can be installed on the legacy x86 NAS.
