chirpa
Apr 01, 2013Luminary
ReadyNAS OS 6.9.3 | Run on existing x86 (4.2) #notsupported
There are a few threads on this, showing how to convert 6.0 firmware to run on the 4.2 platform. I am combining the information here, so it is easier to digest. This is UNSUPPORTED by NETGEAR. Do...
Aiddy
Sep 04, 2015Aspirant
Hi,
Sorry to revive an old thread, I have just taken the plunge and updated my Pro Pioneer Edition using the 'PREP4TOR6_0.1-x86.bin' & 'R4toR6_latest.bin' files downloaded on the 27th August. Nearly everything is working perfectly but I do have 1 question & 1 problem.
Question, by NAS shows it's running 6.3.5 - Is that correct? As the Pro Pioneer is an x86 based machine I would have expected 6.2.4 at best?
Problem, I am unable to logon to Vault. I keep getting a 'Vault Login Failed' error. (everything works if I logon via browser - so my account is ok)
I know there has been a recent (20th July 2015) update to Vault to v2.9.23 which I had carried out prior to upgrading (i.e. whlst on FrontView 4.x) so am wondering if this could be the issue - however, I have tried installing the package from http://www.readynasvault.com/update/ but it keeps failing to install.
Can you help?
cheers,
Adrian
Sandshark
Sep 07, 2015Sensei
All of my legacy systems are running 6.2.4, which reports to be the latest available version. So I don't know how you could actually be running 6.3.5. Where is this reported, in Frontview, RAIDar, or both?
- StephenBSep 07, 2015Guru - Experienced User
Note this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-upgrade-question-on-legacy-Pro-6/m-p/979096#U979096
6.3.5 (beta rc2) can be installed on the legacy x86 NAS.
