cchoate
Mar 21, 2017Aspirant
Resilio Sync resets after reboot
I have Resilio 2.4.4 installed on my Readynas 314 with firmware 6.6.1. I install the app, do the first time set up then add folders to start syncing. If I reboot my Readynas 314 Resilio sync looses all settings and wants me to start over from scratch. This happens everytime I reboot without fail. I've tried uninstall / reinstall several times. This doesn't happen with any of my windows machines so I believe it's only an issue with Readynas. Anyone else having this issue or solved it? Thanks in advance.
- JennCNETGEAR Employee Retired
Hello cchoate,
Did you get the app from apps download site or from the admin page's available apps?
Welcome to the community!
Hello cchoate,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- cchoateAspirant
Yes, I did download from the app download site on the Netgear web page. This issue seems to have started when I updated the firmware to 6.6.1 on my Readynas 314. Not sure if this is a bug on the Netgear firmware or the Resilio app.
