horim80's avatar
horim80
Guide
Aug 04, 2011
UDP 514 port open for remote logging on syslogd . HELP!
Hi,
I want to remote logging on readynas.
So I did below,
ReadyNAS-PRO:/# vim /etc/init.d/sysklogd
# then I've added below line for receive log from remote device.
SYSLOGD="-r -m 0"
then I restart the syslogd
ReadyNAS-PRO:/# /etc/init.d/sysklogd restart
Restarting system log daemon: syslogd.
and check the udp 514 port open
ReadyNAS-PRO:/# netstat -an | grep :514
udp 0 0 0.0.0.0:514 0.0.0.0:*
finally it work well and receive log from remote device successfully.
BUT, when I reboot the NAS, upd 514 port blocked again....
netstat -an | grep :514 --> nothing..
For work properly, I have to restart the syslogd manually...
How can I open the udp 514 port consistently?
  • If you added the "SYSLOGD="-r -m 0" before the line "test ! -r /etc/default/syslogd || . /etc/default/syslogd" the SYSLOGD far able was redefined.
    You should edit the file "/etc/default/syslogd" and modify the definition of SYSLOGD in there.
    I also added "SYSLOGD="-r -m 0" to "/etc/default/syslogd" as you said but it doesn't work either.. :(
    #! /bin/sh
    # /etc/init.d/sysklogd: start the system log daemon.
    SYSLOGD="-r -m 0"
    PATH=/bin:/usr/bin:/sbin:/usr/sbin
    pidfile=/var/run/syslogd.pid
    binpath=/sbin/syslogd
    test -x $binpath || exit 0
    create_xconsole()
    if [ ! -e /dev/xconsole ]; then
    mknod -m 640 /dev/xconsole p
    else
    chmod 0640 /dev/xconsole
    fi
    chown root:adm /dev/xconsole
    running()
    # No pidfile, probably no daemon present
    if [ ! -f $pidfile ]
    then
    return 1
    fi
    pid=`cat $pidfile`
    # No pid, probably no daemon present
    if [ -z "$pid" ]
    then
    return 1
    fi
    if [ ! -d /proc/$pid ]
    then
    return 1
    fi
    cmd=`cat /proc/$pid/cmdline | tr "\000" "\n"|head -n 1`
    # No syslogd?
    if [ "$cmd" != "$binpath" ]
    then
    return 1
    fi
    return 0
    case "$1" in
    start)
    echo -n "Starting system log daemon: syslogd"
    create_xconsole
    start-stop-daemon --start --quiet --exec $binpath -- $SYSLOGD
    echo "."
    stop)
    echo -n "Stopping system log daemon: syslogd"
    start-stop-daemon --stop --quiet --exec $binpath --pidfile $pidfile
    echo "."
    reload|force-reload)
    echo -n "Reloading system log daemon: syslogd"
    start-stop-daemon --stop --quiet --signal 1 --exec $binpath --pidfile $pidfile
    echo "."
    restart)
    echo -n "Restarting system log daemon: syslogd"
    sleep 1
    echo "."
    reload-or-restart)
    if running
    then
    else
    fi
    echo "."
    echo "Usage: /etc/init.d/sysklogd {start|stop|reload|restart|force-reload|reload-or-restart}"
    exit 1
    esac
    exit 0
    # Top configuration file for syslogd
    # Full documentation of possible arguments are found in the manpage
    # syslogd(8).
    # For remote UDP logging use SYSLOGD="-r"
    SYSLOGD="-r -m 0"
    Any advice?
  • All I did was edit my "/etc/default/syslogd" file like this:
    # syslogd(8).
    SYSLOGD="-r"
    Ran the command:
    Looking at the processes bound to ports I see:
    mynas:~# lsof -i -nP | grep ':514'
    syslogd 24688 root 18u IPv4 872288 UDP *:514
    What do you get when you run the command:
  • I have question to you.
    udp 514 port still open after reboot the NAS?
    I configured the NAS completely same as you.
    I restart the syslogd then udp 514 port opened. yes it works at this time.
    but it stop work after I reboot the NAS. udp 514 is not opened.
    This is problem..
  • Have you ever found a solution to this problem? I am having exactly the same issue, remote logging does not work after reboot. If i look at the list of processes after reboot I see that syslogd was started without the -r switch. After I manually restart it (sysklogd restart) - it starts with -r switch and remote loging works as expected. I've made exactly the same changes to /etc/init.d/sysklogd as shown in the first post.
    I have resolved this problem~!
    1. edit /etc/default/syslogd
    SYSLOGD="-r -m0"
    2. add some line to /etc/syslog.conf
    local7.debug                    -/var/log/gs108t.log
    3. create a script at /etc/init.d/ like a below.
    #! /bin/sh
    exit 0
    4. update script to rc.
    update-rc.d script-name defaults
    that's it.
    UDP 514 still opened after reboot!
  • The /etc/inittab defined the default init level as 2 and looking into /etc/rc2.d there are 2 scripts called /etc/init.d/readynas_startup and /etc/rc2.d/S02ToggleSwitchProCPUFan.
    Looking at the file "/etc/init.d/readynas_startup" around line 375 you have:
    # RC2
    echo -n "Starting system log daemon: syslogd" >$OUT
    sync
    /sbin/syslogd -m 0 || (echo "...retrying"; sleep 1; /sbin/syslogd -m 0)
    echo "." >$OUT
    The syslogd is not started using the standard /etc/init.d/sysklogd script it calls the daemon directly.
    I made the following changes to "/etc/init.d/readynas_startup":
    # RC2
    sync
    /sbin/syslogd ${SYSLOGD}-m 0 || (echo "...retrying"; sleep 1; /sbin/syslogd ${SYSLOGD} -m 0)
    echo "." >$OUT
    # RC2
    sync
    echo "." >$OUT
    # RC2
    sync
    echo "." >$OUT
    Thanks! It worked.
ProSupport for Business
