veehexx
Aug 24, 2010Aspirant
2.5" hdd
i've just bought a new hdd for a laptop, and looking at it's spec - http://www.wdc.com/en/products/products.asp?driveid=685, it seems a 1tb drive is also available - i find this interesting!
obviously 2.5" drives wont natively fit inside a readynas since they are designed around 3.5" drives.
however, i'd be interested in looking into 2.5" drives in the future as a lower powered option vs 3.5" drives.
also, all SSD's are 2.5" afaik.
is there an option to fit 2.5" drives into readynas's? i know you can get adaptors 2.5 > 3.5" bays, but im not sure on the alignment with the sata socket on readynas with such options.
would anyone else find this 2.5" option useful, and what options would users have of fitting 2.5" drives to readynas's?
im specifically interested in maybe a year or twos time when 2tb drives are available in 2.5" factor on the ultra series.
what say you, jedis!?
- mangroveApprentice
emoacht wrote: mangrove
It's interesting. I thought same thing first but abandoned the idea because it would be very tough to make holes in such steel plate without power tools.
By the way, I checked dimensions of screw holes and found that to locate SATA connector of 2.5-inch drive at exactly same place as 3.5-inch drive, two holes in the connector side will be half covered by tray (http://www.flickr.com/photos/35497088@N06/7391031382/).
So, if I do the same as you did, the connector would be 1 or 1.5 mm longer than normal position. It would not make any trouble?
There will be a slight flexing of the circuit board, due to the Readynas' impressively good tolerances :D (a normal drive fits absolutely like a glove). I cannot imagine it being a problem, though, but if you are concerned, you could always file back the front mounting points a little.
The resultant flexing of the board is less than 0.5mm (due to tolerances in the lock lever, etcetera). - mangroveApprenticeI have now modified my instructions with two more alternatives.
The easiest one if you want to use 2.5" drives more or less permanently is adding spacers. In this way, if you go for three screws per tray only, you won't even have the need for power tools -- just a few screws.
Otherwise you can sand/file down the front, where the screws meet the metal, half a millimeter -- which together with overall tolerances in the latch/locking system will lead to a perfect fit with no-to-minimal flex in the circuit board. - emoachtAspirant
I see. I agree that with such slight flex, it will hardly cause a serious issue. - chirpaLuminary
chirpa wrote: My tinkering awhile ago:
That's pretty hardcore.
8)
