MrCyberdude's avatar
Apr 15, 2010
2TB WD20EARS HCL Advanced Format 4k Sectors TLER LCC WDidle3
EDIT: This thread was written before the Readynas group had recognized and addressed the WD Advanced Format HDD's. An issue that remains to this day is the massive LCC(Load Cycle Count) increases due to the original HDD Firmware.
I believe the end of year 2012 WD Red drives address most of the issues that plagued the WD20EARS and WD20EARX but I have not confirmed this.
The LLC (Load Cycle Count) for a majority of my drives has now approached 3Million. Yes Three Million.
There appears to be a New WD20EARS-00MVWB0 which has 3 Platters. As yet untested. http://forums.vr-zone.com/hardware-aren ... etter.html
WDidle3_1_05.zip info works with WD20EARS HDD's viewtopic.php?p=233472#p233472
WD20eaRs HDD's 4KB Alignment issues appears to be FIXED with firmware 4.2.12-T9 viewtopic.php?p=238394#p238394
The SPARC 4KB Fixed Alignment firmware version is looking to be done by July 2010 as mentioned here. viewtopic.php?p=242472#p242472
2TB WD20EARS HCL, Advanced Format 4k Sectors, TLER(Time Limited Error Recovery), LCC(Load_Cycle_Count) info
After reading a fair bit online about the new WD Caviar Green/GP HDD's by WD such as the WD20EARS and their newish 4k sector size,
I am left wondering if the ReadyNAS firmware(existing or Beta) has been updated for this new HDD Sector design?
Could one of the JEDI or anyone else please comment on the following information?
Sorry for what appears like a jumble of information following but its hard to know where to start,
when all i really want is for it to be on the HCL as it is the only WD HDD commonly available here in Melbourne Australia.
This is a very good clear explaination about the 4096B Sector size that replace the historical 512B size
http://www.anandtech.com/show/2888
With the emulation of 512B sectors, there’s the risk that a partition could be misaligned compared to the 4K physical sectors - where it would be unwittingly started in the middle of such a sector. As a result, the clusters of a file system on that partition would end up straddling 4K sectors, which would cause performance problems.
In order to solve the misalignment issue, Western Digital is offering two solutions. The first solution for correcting misaligned partitions is specifically geared towards Win 5.x, and that is an option on the drive itself to use an offset. Through the jumpering of pins 7 and 8 on an Advanced Format drive, the drive controller will use a +1 offset, resolving Win 5.xx’s insistence on starting the first partition at LBA 63 by actually starting it at LBA 64, an aligned position. This is exactly the kind of crude hack it sounds like since it means the operating system is no longer writing to the sector it thinks its writing to, but it’s simple to activate and effective in solving the issue so long as only a single partition is being used. If multiple partitions are being used, then this offset cannot be used as it can negatively impact the later partitions. The offset can also not be removed without repartitioning the drive, as the removal of the offset would break the partition table.
Western Digital Advanced Format What WD have to say which is not very helpful when it comes to linux.
http://www.wdc.com/en/products/advancedformat/index.asp
I have read that TLER is enabled on the WD20EARS. Can anyone here confirm(x seconds) as info is conflicting?
Also the old HDD utilities for spinup and TLER are no longer supported by WD for the EARS drives.
Knowledge Base WD Caviar Green / GP
http://support.wdc.com/product/kb.asp?g ... 08&lang=en
From what I have read do not use the 7-8 Jumper for XP compatibility mode due to more than single partition issue.
Jumper Settings WD20EARS
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... ed=#jumper
ReadyNAS related Fix? Is this already implemented?
Linux Fix according to WD knowledge base
http://wdc.custhelp.com/cgi-bin/wdc.cfg ... faqid=5357
Problem: The Load/Unload counter for S.M.A.R.T Attribute 193 continues to increase under some distributions of the Linux Operating system.
Affected Models: WD20EADS, WD20EARS, WD15EADS, WD15EARS, WD10EADS, WD10EARS, WD8000AARS, WD7500AADS, WD7500AARS, WD6400AADS, WD6400AARS, WD5000AADS, WD5000AARS
some implementations of Linux, for example, are not optimized for low power storage devices and can cause our drives to wake up at a higher rate than normal.
Solution:
The number of systems using such applications and utilities is limited and customers can resolve this symptom by optimizing their systems with the following three options depending on requirements.
Do not wake up the drives unnecessarily every 10 to 30 seconds or so, thereby gaining substantial power savings and eliminating excess activity. Increasing logging to every 2 minutes would result in 525,600 minutes per year or 262,800 cycles per year. Increase to 5 minutes and cycles would not even be a factor.
a. Linux users: Decrease the logging message
i. Examine your /etc/syslog.conf file for unnecessary logging activity and to optimize its performance. If you don't want to log any system activity, consider disabling syslogd and klogd entirely; or, at the very least, minimize the amount of logging your system performs. You can also prefix each entry with the minus sign (-) to omit syncing the file after each log entry. This will log anything with a priority of info or higher, but lower than warning, to /var/log/messages or /var/log/mail without needing to sync to disk after each write. Since we want to keep all messages with a priority of warning, this will be logged to a different file without disabling disk syncing (to prevent data loss in the event of a system crash).
*.warning /var/log/syslog
*.info;*.!warning;mail.none -/var/log/messages
mail.info;mail.!warning -/var/log/mailii. Another item to be aware of is the -- MARK -- messages that syslogd(8) writes. This will affect your hard drive inactivity settings. You can simply disable this by running syslogd(8) with:
if [ -x /usr/sbin/syslogd -a -x /usr/sbin/klogd ]; then
# '-m 0' disabled 'MARK' messages
/usr/sbin/syslogd -m 0
sleep 1
# '-c 3' displays errors on console
# '-x' turns off broken EIP translation
/usr/sbin/klogd -c 3 -x
fi
b. Modify OS power management timers in control panel
Disable Advanced power management using standard ATA command (Uses more power as turns off all low power modes but results in no load/unload cycles)
Linux users add following (hdparm -B 255 /dev/sdX where X is your hard drive device)
ATA users can disable APM usually controlled via BIOS and/or OS.ATA users can disable APM usually controlled via BIOS and/or OS.
Set Idle3 to max time (effectively turns off load/unload power saving feature thus will use more power) per below link
Any Links I have missed please add, especially form here.
ProSupport for Business
