fondy's avatar
fondy
Tutor
Apr 13, 2012
4k sector ?
Hi, I am new to readynas.
I just bought an Ultra 4. At same time I bought 4 Seagate Barracuda Green 2TB SATA 6Gb/s, (SATA 3.0), 64MB Cache, 5900RPM, 3.5".
I installed the new discs in the new Ultra. The Ultra is using Readiator 4.2.19
I took a performance test with drag and drop a 3 gb file from and to the Ultra,and got 66 mb/s read and 31mb/s write.
Tried several times with different files at 1gb, 2gb and 3gb, and the write was the same, 29-32 mb/s
I am using Netgear GS716Tv2 as switch between the Ultra and the PC and Jumbo is on both at the Nic at the PC and at the Ultra, the switch is using 9216 at the ports.
I read this forum, and saw that low write til the Readynas could be that the disk sectors was 512bytes instead of 4K.
Under I have the partion.log. Am I using 4K sectors ?
Regards Paal
The partion.log:
***** partition output for sda *****
Disk /dev/sda: 3907029168 sectors, 1.8 TiB
Logical sector size: 512 bytes
Disk identifier (GUID): 3AC0628E-FAC3-40CF-BD2F-47CA398F55CB
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 3907029134
Partitions will be aligned on 64-sector boundaries
Total free space is 4092 sectors (2.0 MiB)
Number Start (sector) End (sector) Size Code Name
1 64 8388671 4.0 GiB FD00
2 8388672 9437247 512.0 MiB FD00
3 9437248 3907025072 1.8 TiB FD00
Disk /dev/sda: 243201 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
***** partition output for sdb *****
Disk /dev/sdb: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 90CE1EC8-F613-4B37-8987-9A5DF796BF9D
Disk /dev/sdb: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
***** partition output for sdc *****
Disk /dev/sdc: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): EBACBCC1-0CAB-4532-A27A-3713C343721D
Disk /dev/sdc: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdc1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdc2 0 - 0 0 0 Empty
/dev/sdc3 0 - 0 0 0 Empty
/dev/sdc4 0 - 0 0 0 Empty
***** partition output for sdd *****
Disk /dev/sdd: 3907029168 sectors, 1.8 TiB
Disk identifier (GUID): 5FB8E81B-D308-4440-9A8E-6D8BEC3D94E0
Disk /dev/sdd: 243201 cylinders, 255 heads, 63 sectors/track
/dev/sdd1 0+ 242251- 242252- 1953514583+ ee EFI GPT
/dev/sdd2 0 - 0 0 0 Empty
/dev/sdd3 0 - 0 0 0 Empty
/dev/sdd4 0 - 0 0 0 Empty
ProSupport for Business
