Dewdman42
Jun 26, 2025Virtuoso
524X Can't factory reset, help
Using 524X with firmware 6.10.9 Finally had a disk fail. the disk test option from front view reporting error, but no reasons given, smart status wasn't showing errors. well I tried to re...
Jul 17, 2025Guru - Experienced User
Dewdman42 wrote:# 1 Extended offline Completed: read failure 60% 60172 1210183120
# 2 Extended offline Completed: read failure 10% 60161 1433936648
Dewdman42 wrote:Error 19443 occurred at disk power-on lifetime: 42602 hours (1775 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 61 02 00 00 00 a0 Device Fault; Error: ABRT
I was refering to these reports.
I don't know what you saw in smartctrl -h. Unfortunately, the ReadyNAS software isn't as good at reporting disk errors as it should be.
