Yoji
Dec 27, 2013Aspirant
6.1.5 Are you crazy? or am I confused?
OK.. just saw that 6.1.5 is released...
So I think "great.. they should have sorted the IE11 issue"
And sure enough.. release notes say "4.Compatibility improvements for Windows 8.1 Internet Explorer 11.".. OK - I got IE11 on win 7.. but I guess thats close enough...
But then I see... point 11.. and think.. WTF.. To remind people.. 11 says
"11.Improved performance with large volumes (Most likely seen on the ReadyNAS 104). A factory default is required to make the changes. Copy all data off the ReadyNAS, upgrade the firmware, factory default the unit, and copy all data back onto the device"
So hang on.. what are you saying?... you saying if I just want the performance improves I need do the "copy off, upgrade, copy back".. or I have to do that irrespective?
Half of me says.. "they MUST mean its just for the performance installs"...as there is NO WAY they could issue such an update without a MASSIVE warning.. number 1 on the list.. to say your data at risk if you do this update.. not stuff it in an number 11 almost as an aside...
And surely - they would not tie a required update (i.e. make it IE11 compatible).. with the need to do a complete rebuild...
But the other half of me says.. "its not clear... and 11 seems like a change that happens for all, does not sound optional...and for something so important.. how can I trust them if they cant be clear, one way or the other...and it seems like they can mess up USB 3 and still think its good enough to push out... are they a bunch of professionals doing this? or Muppets?"
My stuff is backed up.. but that's not the point...
The point is.. you need be crystal clear..and your not :evil:
Can someone clarify please.... its just a little important. May be the update will prompt and be clear.. but this is to important to trust that it will be caught later..
Thanks.
Thanks.
- SchorseAspirantThank you. Your answer encoraged me to take another look at it. Now it works after I used Safari. Think it was FireFox preventing me to access the login page (After stopping/starting FF everything is ok with FF also). After 11h NAS has build up 95% of the RAID1. Thats the action displayed on the Act-LED.
