Wildtexaschef
Dec 01, 2014Aspirant
6.2.0 has no manual to download
There is no manual for the new firmware 6.2.0 release. A manual is needed to explain in better detail the new features, how to use them and what they are. I have several question in regards to 6...
btaroli
Dec 03, 2014Prodigy
checksums and, more specificially, healing, rely upon BtRFS's (or md5 if that's the layer it's happening in ROS6) knowledge of extra copies of blocks and/or parity information at the block level with which it can attempt to recovery from checksum errors. That protection, in BtRFS, occurs even if I choose to disable CoW on a folder (like the one I keep my VM's in). Can I still snapshot that path? You betcha! I do it every single day in my Linux environments. And, yes, the snapshot will result in CoW as data diverges from the snapshot... but once the new blocks are written for the +COW path(s), it stops doing additional CoW on those blocks.
Yes, that can get messy after a long while... but it's part of the mix to be aware of when tweaking around with filesystem behavior. :)
Perhaps some details will diverge from this in terms of how Netgear implemented it (bringing md5 and BtRFS together), but without documentation that's hard to say. I can confirm how it works in a pure BtRFS environment.
