Calder
Jan 19, 2017Guide
6.6.1 did not fix UPS detection problem
Still needed to unplug and re-plug USB cable to UPS after a restart for UPS to be detected. Wed Jan 18 2017 16:51:20 System: New USB UPS detected. Manufacturer: APC, Model: Back-UPS ES 550G, Seri...
powellandy1
Feb 05, 2017Virtuoso
Sorry, what I meant to say was the instructions in the knowledgebase (http://kb.netgear.com/23121/How-do-I-add-a-UPS-to-my-ReadyNAS-OS-6-storage-system) insist the name has to be 'UPS' whereas it appears the name has to be whatever the local NAS calls it - in this case 'UPS1' - and I am not sure if this is by design now (in which case the KB needs updating) or is a bug.
Feb 06, 2017Guru - Experienced User
My NAS all use UPS, not of them name it UPS1.
I suspect there is a bug here - the NAS probably shouldn't have labeled yours UPS1 either.
- powellandy1Feb 06, 2017Virtuoso
I'm clearly very special then!!
- SandsharkFeb 08, 2017Sensei - Experienced User
At some point, did you move the UPS from one USB connection to another? Maybe it somehow thinks (or thought at one point) you have two.
- powellandy1Feb 08, 2017Virtuoso
Good point. I may well have done when troubleshooting the UPS issue in 6.6.0, although I only have the one so by definition only one was plugged in at any time.
