x8x8x
Mar 23, 2012Aspirant
746 Gb=3TB disk
I have a Netgear ReadyNAS Duo v2 (5.3.4) and hard disk WD30EZRX is reported that has a capacity of 746 gigabytes
mdgm-ntgr
Mar 23, 2012NETGEAR Employee Retired
Very odd. Sounds like the disk is still formatted with MBR not GPT.
Try a factory default (wipes all data, settings, everything). On the Dashboard go to Configure > Update > Perform Factory Default and follow the prompts or use the boot menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu#ultra_2_ultra_2_plus_pro_2_duo_v2)
Welcome to the forum!
