rhabbott
Jun 04, 2010Aspirant
Accessing USB drive with Linux
I have a NV+ with external USB drive formatted in EXT3 where backup is copied to this drive. Power supply crapped out in NV+. :-( Plugged the USB drive into a Linux system (Fedora 9) which should...
kernst
Jun 17, 2010Aspirant
[SOLUTION?] I can confirm that the fuse-ext2 module enables at least read-only access to ext3 filesystems with 16K block sizes, such as those created using Frontview on a ReadyNAS NV+ to format an external USB drive. I was able to mount and read files off my external drive with OS X 10.4 on a PowerPC Mac and Ubuntu 9.10 on a PC.
Tested software configuration:
Instructions for Mac OS X:
- Mac OS X 10.4.11 (Tiger)
- MacFUSE 2.0.2 (installed using the .dmg here)
- fuse-ext2 0.0.7 (installed using the .dmg here)
- Ubuntu Linux 9.10 (Karmic)
- Ubuntu fuseext2 package, version 0.3-1, from the "universe" repository
- Official Ubuntu fuse-utils and libfuse2 packages, version 2.7.4-1.1ubuntu4.3
- Install MacFUSE, then install fuse-ext2 (a reboot was not required)
- Determine the device file for the external USB drive and ext3 filesystem using Disk Utility. Mine was /dev/disk2s1.
- Open Terminal and create a folder as a mountpoint--somewhere--for the ext3 filesystem. It doesn't matter where. Even /Volumes is okay, but OS X will remove the folder in /Volumes once you've unmounted the filesystem using Finder.
mkdir "/Volumes/External Drive"
- Open Terminal and run the following:
fuse-ext2 -o ro /dev/disk2s1 "/Volumes/External Drive"
- A new disk icon should appear on the desktop. Unmount it in the usual way when you're done.
- Ensure the "universe" repository is enabled in "Software Sources" (not required for Debian 5.0 "Lenny") and refresh the package listing if necessary (sudo apt-get update in a console). Install the fuseext2 package, which should pull down all the required dependencies:
sudo apt-get install fuseext2
- Determine the device file for the external USB drive and ext3 filesystem using fdisk (dash ell). Mine was /dev/sdb1.
sudo fdisk -l
- Create a mount point somewhere:
mkdir ~/mnt/external
- Run the following in a console (shell):
sudo fuseext2 -o ro,allow_other /dev/sdb1 ~/mnt/external
- Browse to the mount point using your file manager of choice. Use fusermount -u to unmount when you're done:
sudo fusermount -u ~/mnt/external
- The permissions on the external drive may not allow a normal user on the host computer access to all of the files. The easiest way around this is to copy the files somewhere else from inside a root shell (sudo -s), then change the permissions on the copies to (at least) 755 (rwxr-xr-x) for folders and 644 (rw-r--r--) for files.
- I did not test fuse-ext2's experimental read/write support, which is enabled using -o rw+ at the command line. Read the man page for more details.
- On a vanilla Debian system, you probably won't need to use sudo; just run those commands while logged in to a terminal as 'root.'
- For other Linux distros, use your package manager to search for "fuse" and/or "ext2" and install the appropriate package. (Debian "oldstable" [Etch] did not seem to have a fuse-ext2 package at all.) The other steps are the same, with the possible exception of the exact name of the "fuseext2" binary.
Instructions for Linux (Ubuntu/Debian):
Notes:
