Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
jak0lantash
May 14, 2017Mentor
Maybe you want to upvote this "idea": https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Change-the-incredibly-confusing-error-message-quot-remove/idi-p/1271658
Download the logs from the GUI, and look for md127 in dmesg.log.
Kalle13
May 14, 2017Tutor
Hi jak0lantash,
thanks for your reply.
I have downloaded the logs and in the dmesg.log bu there were no entries like "md127".
My Netgear has four disks und is running a RAID 5.
Here a snippet from the volume.log:
RAID data-0: Device: sda3 HostID: 119c1bce UUID: 632ff5fd-6534-2524-9c97-98d780e47e94 Size: 23413000704 Component size: 7804333680 Level: 5 State: inactive Action: idle Flags 0x0 Members: 4 Pool: data-0 Disks: sda: HostID: 119c1bce Flags: 0x0 Size: 7814037168 (3726 GB) Free: 4062 Controller 0 Channel: 0 Model: WDC WD40EFRX-68WT0N0 Serial: WD-WCC4E2XEK9VE Firmware: 82.00A82 RPM: 5400 SMART data Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 25 Start/Stop Count: 6678 Power-On Hours: 2962 Power Cycle Count: 387 Load Cycle Count: 6647 Latest Self Test: Passed sdb: HostID: 119c1bce Flags: 0x0 Size: 7814037168 (3726 GB) Free: 4062 Controller 0 Channel: 1 Model: WDC WD40EFRX-68WT0N0 Serial: WD-WCC4E4CZPUVA Firmware: 82.00A82 RPM: 5400 SMART data Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 25 Start/Stop Count: 6745 Power-On Hours: 2961 Power Cycle Count: 386 Load Cycle Count: 6715 Latest Self Test: Passed sdc: HostID: 119c1bce Flags: 0x0 Size: 7814037168 (3726 GB) Free: 4062 Controller 0 Channel: 2 Model: WDC WD40EFRX-68WT0N0 Serial: WD-WCC4E3XCNPFF Firmware: 82.00A82 RPM: 5400 SMART data Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 25 Start/Stop Count: 6716 Power-On Hours: 2961 Power Cycle Count: 383 Load Cycle Count: 6688 Latest Self Test: Passed sdd: HostID: 119c1bce Flags: 0x0 Size: 7814037168 (3726 GB) Free: 4062 Controller 0 Channel: 3 Model: WDC WD40EFRX-68WT0N0 Serial: WD-WCC4E3JR81HF Firmware: 82.00A82 RPM: 5400 SMART data Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 25 Start/Stop Count: 6503 Power-On Hours: 2961 Power Cycle Count: 383 Load Cycle Count: 6476 Latest Self Test: Passed
Best regards
Kalle
