Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
jak0lantash
May 14, 2017Mentor
Check in dmesg.log again and look for sda3, sdb3, sdc3 and sdd3.
- Kalle13May 14, 2017Tutor
Hi,
I am not an expert with this but I guess sda is down and that's why it can't start.
Here is the snipped out of the dmesg log.scsi 0:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] 4096-byte physical blocks [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Write Protect is off [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:13 2017] ata5: SATA link down (SStatus 0 SControl 300) [Sun May 14 12:31:13 2017] sda: sda1 sda2 sda3 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Attached SCSI disk [Sun May 14 12:31:13 2017] pci 0000:00:04.1: [1c36:8011] type 00 class 0x100000 [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: enabling device (0400 -> 0402) [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: al_crypto_pci_probe: Skipping alg/hash initialization, no allocated channels [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: crc/csum algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: hash algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: al_crypto_pci_probe: Skipping crc initialization, no allocated channels [Sun May 14 12:31:13 2017] usbcore: registered new interface driver usbhid [Sun May 14 12:31:13 2017] usbhid: USB HID core driver [Sun May 14 12:31:13 2017] ip_tables: (C) 2000-2006 Netfilter Core Team [Sun May 14 12:31:13 2017] NET: Registered protocol family 10 [Sun May 14 12:31:13 2017] NET: Registered protocol family 17 [Sun May 14 12:31:13 2017] 8021q: 802.1Q VLAN Support v1.8 [Sun May 14 12:31:13 2017] Key type dns_resolver registered [Sun May 14 12:31:13 2017] Registering SWP/SWPB emulation handler [Sun May 14 12:31:13 2017] registered taskstats version 1 [Sun May 14 12:31:13 2017] BTRFS: using crc32c-generic for crc32c [Sun May 14 12:31:13 2017] Btrfs loaded [Sun May 14 12:31:13 2017] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [Sun May 14 12:31:13 2017] rtc-ds1307 0-0068: setting system clock to 2017-05-14 10:31:13 UTC (1494757873) [Sun May 14 12:31:14 2017] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd [Sun May 14 12:31:14 2017] usb-storage 2-3:1.0: USB Mass Storage device detected [Sun May 14 12:31:14 2017] scsi host6: usb-storage 2-3:1.0 [Sun May 14 12:31:15 2017] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata4.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata4.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata4.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata2.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata2.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] scsi 1:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Write Protect is off [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] ata3.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata3.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] scsi 2:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Write Protect is off [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] scsi 3:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Write Protect is off [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] sdb: sdb1 sdb2 sdb3 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Attached SCSI disk [Sun May 14 12:31:16 2017] sdd: sdd1 sdd2 sdd3 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Attached SCSI disk [Sun May 14 12:31:16 2017] sdc: sdc1 sdc2 sdc3 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Attached SCSI disk [Sun May 14 12:31:16 2017] ata6: SATA link down (SStatus 0 SControl 300)
Best regards
Kalle- jak0lantashMay 14, 2017Mentor
You should have further mentions of sda3, and md127 lower than that in dmesg.log.
If you don't, at the end volume.log, there is a section "=== df -h ===", check the line:
/dev/md0 4.0G 517M 3.3G 14% /
Is it 100% full?
You can also search systemd-journal.log and mdstat.log for mentions of md127.
How many HDDs do you have in the NAS?
Hallo,
there are no further mentions of sda3, and md127 in the dmesg.log. I´ve cutted it all out last time.
As you requested here are the outputs of:
~ volume.log ~
/dev/md0 3.7G 1.6G 1.9G 46% /
~ volume.log ~
"md127" can be found 10 times in the file. This is the whole cutout with all of them.
-- Logs begin at Sat 2017-03-25 22:09:02 CET, end at Sun 2017-05-14 12:33:55 CEST. -- May 12 22:00:37 ReadyNAS systemd[1]: Starting Create Static Device Nodes in /dev... May 12 22:00:37 ReadyNAS systemd[1]: Mounting FUSE Control File System... May 12 22:00:37 ReadyNAS systemd[1]: Mounting Configuration File System... May 12 22:00:37 ReadyNAS systemd[1]: Starting Apply Kernel Variables... May 12 22:00:37 ReadyNAS systemd[1]: Mounted FUSE Control File System. May 12 22:00:37 ReadyNAS systemd[1]: Mounted Configuration File System. May 12 22:00:37 ReadyNAS systemd[1]: Started hwclock.service. May 12 22:00:37 ReadyNAS systemd[1]: Started Apply Kernel Variables. May 12 22:00:37 ReadyNAS systemd[1]: Reached target System Time Synchronized. May 12 22:00:37 ReadyNAS systemd[1]: Starting Remount Root and Kernel File Systems... May 12 22:00:37 ReadyNAS systemd[1]: Started Create Static Device Nodes in /dev. May 12 22:00:37 ReadyNAS systemd[1]: Started Remount Root and Kernel File Systems. May 12 22:00:37 ReadyNAS systemd[1]: Starting Rebuild Hardware Database... May 12 22:00:37 ReadyNAS systemd[1]: Starting Load/Save Random Seed... May 12 22:00:37 ReadyNAS systemd-journald[1018]: Journal started May 12 22:00:37 ReadyNAS systemd[1]: Starting udev Kernel Device Manager... May 12 22:00:37 ReadyNAS systemd[1]: Started Journal Service. May 12 22:00:37 ReadyNAS systemd[1]: Started Load/Save Random Seed. May 12 22:00:37 ReadyNAS systemd[1]: Starting Flush Journal to Persistent Storage... May 12 22:00:38 ReadyNAS systemd[1]: Started Flush Journal to Persistent Storage. May 12 22:00:38 ReadyNAS kernel: md: md127 stopped. May 12 22:00:38 ReadyNAS kernel: md: bind<sdb3> May 12 22:00:38 ReadyNAS kernel: md: bind<sdc3> May 12 22:00:38 ReadyNAS kernel: md: bind<sdd3> May 12 22:00:38 ReadyNAS kernel: md: bind<sda3> May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sda3 operational as raid disk 0 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdd3 operational as raid disk 3 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdc3 operational as raid disk 2 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdb3 operational as raid disk 1 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: allocated 4274kB May 12 22:00:38 ReadyNAS kernel: md/raid:md127: raid level 5 active with 4 out of 4 devices, algorithm 2 May 12 22:00:38 ReadyNAS kernel: RAID conf printout: May 12 22:00:38 ReadyNAS kernel: --- level:5 rd:4 wd:4 May 12 22:00:38 ReadyNAS kernel: disk 0, o:1, dev:sda3 May 12 22:00:38 ReadyNAS kernel: disk 1, o:1, dev:sdb3 May 12 22:00:38 ReadyNAS kernel: disk 2, o:1, dev:sdc3 May 12 22:00:38 ReadyNAS kernel: disk 3, o:1, dev:sdd3 May 12 22:00:38 ReadyNAS kernel: md127: detected capacity change from 0 to 11987456360448 May 12 22:00:38 ReadyNAS systemd[1]: Started udev Kernel Device Manager. May 12 22:00:38 ReadyNAS start_raids[1004]: mdadm: /dev/md/data-0 has been started with 4 drives. May 12 22:00:38 ReadyNAS systemd[1]: Found device /dev/md1. May 12 22:00:38 ReadyNAS systemd[1]: Activating swap md1... May 12 22:00:38 ReadyNAS kernel: Adding 1046524k swap on /dev/md1. Priority:-1 extents:1 across:1046524k May 12 22:00:38 ReadyNAS systemd[1]: Activated swap md1. May 12 22:00:38 ReadyNAS systemd[1]: Started Rebuild Hardware Database. May 12 22:00:39 ReadyNAS kernel: BTRFS: device label 119c1bce:data devid 1 transid 13920 /dev/md127 May 12 22:00:39 ReadyNAS systemd[1]: Found device /dev/disk/by-label/119c1bce:data. May 12 22:00:39 ReadyNAS systemd[1]: Started MD arrays. May 12 22:00:39 ReadyNAS systemd[1]: Starting udev Coldplug all Devices... May 12 22:00:39 ReadyNAS systemd[1]: Reached target Local File Systems (Pre). May 12 22:00:39 ReadyNAS systemd[1]: Mounting /data... May 12 22:00:39 ReadyNAS systemd[1]: Reached target Swap. May 12 22:00:39 ReadyNAS systemd[1]: Started udev Coldplug all Devices. May 12 22:00:39 ReadyNAS systemd[1]: Starting udev Wait for Complete Device Initialization... May 12 22:00:39 ReadyNAS systemd[1]: Found device /dev/ttyS0. May 12 22:00:40 ReadyNAS systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. May 12 22:00:40 ReadyNAS systemd-udevd[1614]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS systemd-udevd[1390]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[1970]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1972]: disk event handler called for add May 12 22:00:40 ReadyNAS systemd-udevd[1677]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[1988]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1993]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1970]: Sending disk add event for /dev/sdb to readynasd. May 12 22:00:40 ReadyNAS disk_event_handler[1972]: Sending disk add event for /dev/sdc to readynasd. May 12 22:00:40 ReadyNAS systemd-udevd[1682]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[2012]: disk event handler called for add May 12 22:00:41 ReadyNAS disk_event_handler[2012]: Sending disk add event for /dev/sda to readynasd. May 12 22:00:41 ReadyNAS disk_event_handler[1993]: Sending disk add event for /dev/sdd to readynasd. May 12 22:00:41 ReadyNAS disk_event_handler[1988]: Sending disk add event for /dev/sde to readynasd. May 12 22:00:41 ReadyNAS systemd-udevd[1587]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1392]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1391]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1690]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1614]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1390]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2091]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2092]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2093]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2095]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2096]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2094]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd[1]: Started udev Wait for Complete Device Initialization. May 12 22:00:43 ReadyNAS systemd[1]: Mounted /data. May 12 22:00:43 ReadyNAS systemd[1]: Reached target Local File Systems. May 12 22:00:43 ReadyNAS systemd[1]: Starting Create Volatile Files and Directories... May 12 22:00:43 ReadyNAS systemd[1]: Starting LSB: Add to mtab the entry for /dev.... May 12 22:00:43 ReadyNAS systemd[1]: Mounting Apps Directory... May 12 22:00:43 ReadyNAS systemd[1]: Mounting Home Directory... May 12 22:00:43 ReadyNAS systemd[1]: Mounted Apps Directory. May 12 22:00:43 ReadyNAS systemd[1]: Mounted Home Directory. May 12 22:00:43 ReadyNAS systemd[1]: Started LSB: Add to mtab the entry for /dev.. May 12 22:00:43 ReadyNAS systemd[1]: Started Create Volatile Files and Directories. May 12 22:00:43 ReadyNAS systemd[1]: Starting Update UTMP about System Boot/Shutdown... May 12 22:00:43 ReadyNAS systemd[1]: Started Update UTMP about System Boot/Shutdown. May 12 22:00:43 ReadyNAS systemd[1]: Reached target System Initialization. May 12 22:00:43 ReadyNAS systemd[1]: Started Timer for ReadyNAS Update Service. May 12 22:00:43 ReadyNAS systemd[1]: Listening on D-Bus System Message Bus Socket. May 12 22:00:43 ReadyNAS systemd[1]: Started Timer for Debian Package List Updater. May 12 22:00:43 ReadyNAS systemd[1]: Started Daily Cleanup of Temporary Directories. May 12 22:00:43 ReadyNAS systemd[1]: Started Anti-Virus Definition Update Timer. May 12 22:00:43 ReadyNAS systemd[1]: Listening on RPCbind Server Activation Socket. May 12 22:00:44 ReadyNAS systemd[1]: Started Log Truncate Timer. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Timers. May 12 22:00:44 ReadyNAS systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Sockets. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Basic System. May 12 22:00:44 ReadyNAS systemd[1]: Started Regular background program processing daemon. May 12 22:00:44 ReadyNAS cron[2179]: (CRON) INFO (pidfile fd = 3) May 12 22:00:44 ReadyNAS systemd[1]: Started MD repair service. May 12 22:00:44 ReadyNAS systemd[1]: Starting Login Service... May 12 22:00:44 ReadyNAS cron[2179]: (CRON) INFO (Running @reboot jobs) May 12 22:00:44 ReadyNAS systemd[1]: Starting Network bonding... May 12 22:00:44 ReadyNAS systemd[1]: Started WSD/LLMNR Discovery/Name Service Daemon. May 12 22:00:44 ReadyNAS wsdd2[2184]: starting. May 12 22:00:44 ReadyNAS systemd-udevd[2197]: Could not generate persistent MAC address for bond0: No such file or directory May 12 22:00:44 ReadyNAS kernel: bonding: bond0 is being created... May 12 22:00:44 ReadyNAS systemd[1]: Starting LSB: Startup script for the Logitech Media Server... May 12 22:00:44 ReadyNAS kernel: IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready May 12 22:00:44 ReadyNAS kernel: 8021q: adding VLAN 0 to HW filter on device bond0 May 12 22:00:44 ReadyNAS kernel: bond0: Setting MII monitoring interval to 100 May 12 22:00:44 ReadyNAS kernel: bond0: Setting xmit hash policy to layer2+3 (2) May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: al_eth_down May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: dma state didn't change to Disable May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: failed to change state, error -110 May 12 22:00:44 ReadyNAS systemd[1]: Started MD monitoring service. May 12 22:00:44 ReadyNAS kernel: bond0: Adding slave eth1 May 12 22:00:44 ReadyNAS kernel: configured MAC to RGMII mode: May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: using MSI-X per Queue interrupt mode May 12 22:00:44 ReadyNAS kernel: libphy: al mdio bus: probed May 12 22:00:44 ReadyNAS systemd[1]: Started D-Bus System Message Bus. May 12 22:00:44 ReadyNAS logitechmediaserver[2226]: Making sure that Logitech Media Server is not running first: No process in pidfile '/var/run/logitechmediaserver.pid' found running; none killed. May 12 22:00:44 ReadyNAS logitechmediaserver[2226]: Starting Logitech Media Server. May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md0 May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: phy[5]: device 18:05, driver Atheros 8035 ethernet May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: phy[5]:supported 2ef adv 2ef May 12 22:00:44 ReadyNAS kernel: bond0: Enslaving eth1 as a backup interface with a down link May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:01.0 eth0: al_eth_down May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: dma state didn't change to Disable May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: failed to change state, error -110 May 12 22:00:44 ReadyNAS kernel: bond0: Adding slave eth0 May 12 22:00:44 ReadyNAS kernel: configured MAC to RGMII mode: May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:01.0 eth0: using MSI-X per Queue interrupt mode May 12 22:00:44 ReadyNAS kernel: libphy: al mdio bus: probed May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md1 May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md127
~ mdstat.log ~
"md127" can´t be found in the file.
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md1 : active raid6 sda2[0] sdc2[3] sdb2[2] sdd2[1] 1046528 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [UUUU] md0 : active raid1 sda1[4] sdd1[3] sdc1[2] sdb1[5] 4190208 blocks super 1.2 [4/4] [UUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Sun Apr 3 06:27:48 2016 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sun May 14 12:33:50 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Name : 119c1bce:0 (local to host 119c1bce) UUID : 2495045b:2aa5bd3c:8cff9bb5:de4e769c Events : 367 Number Major Minor RaidDevice State 4 8 1 0 active sync /dev/sda1 5 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 /dev/md/1: Version : 1.2 Creation Time : Sat Apr 30 23:31:42 2016 Raid Level : raid6 Array Size : 1046528 (1022.00 MiB 1071.64 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Mon May 8 01:08:11 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Name : 119c1bce:1 (local to host 119c1bce) UUID : 2863873a:78baa761:890ee932:2551648e Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync /dev/sda2 1 8 50 1 active sync /dev/sdd2 2 8 18 2 active sync /dev/sdb2 3 8 34 3 active sync /dev/sdc2It seems that the RAID is ok, am I right?
Best regards
Kalle
