Kalle13's avatar
Kalle13
Tutor
May 13, 2017
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello,   I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have:   ReadyNAS 516 just upgraded to 6.7....
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 19, 2017
    You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
    There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
ProSupport for Business
