Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
Kalle13
May 14, 2017Tutor
Hi,
I am not an expert with this but I guess sda is down and that's why it can't start.
Here is the snipped out of the dmesg log.
scsi 0:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] 4096-byte physical blocks [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Write Protect is off [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:13 2017] ata5: SATA link down (SStatus 0 SControl 300) [Sun May 14 12:31:13 2017] sda: sda1 sda2 sda3 [Sun May 14 12:31:13 2017] sd 0:0:0:0: [sda] Attached SCSI disk [Sun May 14 12:31:13 2017] pci 0000:00:04.1: [1c36:8011] type 00 class 0x100000 [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: enabling device (0400 -> 0402) [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: al_crypto_pci_probe: Skipping alg/hash initialization, no allocated channels [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.1: crc/csum algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: hash algorithms registered in /proc/crypto [Sun May 14 12:31:13 2017] al_crypto 0000:00:04.0: al_crypto_pci_probe: Skipping crc initialization, no allocated channels [Sun May 14 12:31:13 2017] usbcore: registered new interface driver usbhid [Sun May 14 12:31:13 2017] usbhid: USB HID core driver [Sun May 14 12:31:13 2017] ip_tables: (C) 2000-2006 Netfilter Core Team [Sun May 14 12:31:13 2017] NET: Registered protocol family 10 [Sun May 14 12:31:13 2017] NET: Registered protocol family 17 [Sun May 14 12:31:13 2017] 8021q: 802.1Q VLAN Support v1.8 [Sun May 14 12:31:13 2017] Key type dns_resolver registered [Sun May 14 12:31:13 2017] Registering SWP/SWPB emulation handler [Sun May 14 12:31:13 2017] registered taskstats version 1 [Sun May 14 12:31:13 2017] BTRFS: using crc32c-generic for crc32c [Sun May 14 12:31:13 2017] Btrfs loaded [Sun May 14 12:31:13 2017] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [Sun May 14 12:31:13 2017] rtc-ds1307 0-0068: setting system clock to 2017-05-14 10:31:13 UTC (1494757873) [Sun May 14 12:31:14 2017] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd [Sun May 14 12:31:14 2017] usb-storage 2-3:1.0: USB Mass Storage device detected [Sun May 14 12:31:14 2017] scsi host6: usb-storage 2-3:1.0 [Sun May 14 12:31:15 2017] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata4.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata4.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata4.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [Sun May 14 12:31:16 2017] ata2.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata2.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] scsi 1:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Write Protect is off [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] ata3.00: ATA-9: WDC WD40EFRX-68WT0N0, 82.00A82, max UDMA/133 [Sun May 14 12:31:16 2017] ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [Sun May 14 12:31:16 2017] ata3.00: configured for UDMA/133 [Sun May 14 12:31:16 2017] scsi 2:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Write Protect is off [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] scsi 3:0:0:0: Direct-Access ATA WDC WD40EFRX-68W 0A82 PQ: 0 ANSI: 5 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] 4096-byte physical blocks [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Write Protect is off [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [Sun May 14 12:31:16 2017] sdb: sdb1 sdb2 sdb3 [Sun May 14 12:31:16 2017] sd 1:0:0:0: [sdb] Attached SCSI disk [Sun May 14 12:31:16 2017] sdd: sdd1 sdd2 sdd3 [Sun May 14 12:31:16 2017] sd 3:0:0:0: [sdd] Attached SCSI disk [Sun May 14 12:31:16 2017] sdc: sdc1 sdc2 sdc3 [Sun May 14 12:31:16 2017] sd 2:0:0:0: [sdc] Attached SCSI disk [Sun May 14 12:31:16 2017] ata6: SATA link down (SStatus 0 SControl 300)
Best regards
Kalle
jak0lantash
May 14, 2017Mentor
You should have further mentions of sda3, and md127 lower than that in dmesg.log.
If you don't, at the end volume.log, there is a section "=== df -h ===", check the line:
/dev/md0 4.0G 517M 3.3G 14% /
Is it 100% full?
You can also search systemd-journal.log and mdstat.log for mentions of md127.
How many HDDs do you have in the NAS?
- Kalle13May 14, 2017Tutor
Hallo,
there are no further mentions of sda3, and md127 in the dmesg.log. I´ve cutted it all out last time.
As you requested here are the outputs of:
~ volume.log ~
/dev/md0 3.7G 1.6G 1.9G 46% /
~ volume.log ~
"md127" can be found 10 times in the file. This is the whole cutout with all of them.
-- Logs begin at Sat 2017-03-25 22:09:02 CET, end at Sun 2017-05-14 12:33:55 CEST. -- May 12 22:00:37 ReadyNAS systemd[1]: Starting Create Static Device Nodes in /dev... May 12 22:00:37 ReadyNAS systemd[1]: Mounting FUSE Control File System... May 12 22:00:37 ReadyNAS systemd[1]: Mounting Configuration File System... May 12 22:00:37 ReadyNAS systemd[1]: Starting Apply Kernel Variables... May 12 22:00:37 ReadyNAS systemd[1]: Mounted FUSE Control File System. May 12 22:00:37 ReadyNAS systemd[1]: Mounted Configuration File System. May 12 22:00:37 ReadyNAS systemd[1]: Started hwclock.service. May 12 22:00:37 ReadyNAS systemd[1]: Started Apply Kernel Variables. May 12 22:00:37 ReadyNAS systemd[1]: Reached target System Time Synchronized. May 12 22:00:37 ReadyNAS systemd[1]: Starting Remount Root and Kernel File Systems... May 12 22:00:37 ReadyNAS systemd[1]: Started Create Static Device Nodes in /dev. May 12 22:00:37 ReadyNAS systemd[1]: Started Remount Root and Kernel File Systems. May 12 22:00:37 ReadyNAS systemd[1]: Starting Rebuild Hardware Database... May 12 22:00:37 ReadyNAS systemd[1]: Starting Load/Save Random Seed... May 12 22:00:37 ReadyNAS systemd-journald[1018]: Journal started May 12 22:00:37 ReadyNAS systemd[1]: Starting udev Kernel Device Manager... May 12 22:00:37 ReadyNAS systemd[1]: Started Journal Service. May 12 22:00:37 ReadyNAS systemd[1]: Started Load/Save Random Seed. May 12 22:00:37 ReadyNAS systemd[1]: Starting Flush Journal to Persistent Storage... May 12 22:00:38 ReadyNAS systemd[1]: Started Flush Journal to Persistent Storage. May 12 22:00:38 ReadyNAS kernel: md: md127 stopped. May 12 22:00:38 ReadyNAS kernel: md: bind<sdb3> May 12 22:00:38 ReadyNAS kernel: md: bind<sdc3> May 12 22:00:38 ReadyNAS kernel: md: bind<sdd3> May 12 22:00:38 ReadyNAS kernel: md: bind<sda3> May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sda3 operational as raid disk 0 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdd3 operational as raid disk 3 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdc3 operational as raid disk 2 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: device sdb3 operational as raid disk 1 May 12 22:00:38 ReadyNAS kernel: md/raid:md127: allocated 4274kB May 12 22:00:38 ReadyNAS kernel: md/raid:md127: raid level 5 active with 4 out of 4 devices, algorithm 2 May 12 22:00:38 ReadyNAS kernel: RAID conf printout: May 12 22:00:38 ReadyNAS kernel: --- level:5 rd:4 wd:4 May 12 22:00:38 ReadyNAS kernel: disk 0, o:1, dev:sda3 May 12 22:00:38 ReadyNAS kernel: disk 1, o:1, dev:sdb3 May 12 22:00:38 ReadyNAS kernel: disk 2, o:1, dev:sdc3 May 12 22:00:38 ReadyNAS kernel: disk 3, o:1, dev:sdd3 May 12 22:00:38 ReadyNAS kernel: md127: detected capacity change from 0 to 11987456360448 May 12 22:00:38 ReadyNAS systemd[1]: Started udev Kernel Device Manager. May 12 22:00:38 ReadyNAS start_raids[1004]: mdadm: /dev/md/data-0 has been started with 4 drives. May 12 22:00:38 ReadyNAS systemd[1]: Found device /dev/md1. May 12 22:00:38 ReadyNAS systemd[1]: Activating swap md1... May 12 22:00:38 ReadyNAS kernel: Adding 1046524k swap on /dev/md1. Priority:-1 extents:1 across:1046524k May 12 22:00:38 ReadyNAS systemd[1]: Activated swap md1. May 12 22:00:38 ReadyNAS systemd[1]: Started Rebuild Hardware Database. May 12 22:00:39 ReadyNAS kernel: BTRFS: device label 119c1bce:data devid 1 transid 13920 /dev/md127 May 12 22:00:39 ReadyNAS systemd[1]: Found device /dev/disk/by-label/119c1bce:data. May 12 22:00:39 ReadyNAS systemd[1]: Started MD arrays. May 12 22:00:39 ReadyNAS systemd[1]: Starting udev Coldplug all Devices... May 12 22:00:39 ReadyNAS systemd[1]: Reached target Local File Systems (Pre). May 12 22:00:39 ReadyNAS systemd[1]: Mounting /data... May 12 22:00:39 ReadyNAS systemd[1]: Reached target Swap. May 12 22:00:39 ReadyNAS systemd[1]: Started udev Coldplug all Devices. May 12 22:00:39 ReadyNAS systemd[1]: Starting udev Wait for Complete Device Initialization... May 12 22:00:39 ReadyNAS systemd[1]: Found device /dev/ttyS0. May 12 22:00:40 ReadyNAS systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. May 12 22:00:40 ReadyNAS systemd-udevd[1614]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS systemd-udevd[1390]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[1970]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1972]: disk event handler called for add May 12 22:00:40 ReadyNAS systemd-udevd[1677]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[1988]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1993]: disk event handler called for add May 12 22:00:40 ReadyNAS disk_event_handler[1970]: Sending disk add event for /dev/sdb to readynasd. May 12 22:00:40 ReadyNAS disk_event_handler[1972]: Sending disk add event for /dev/sdc to readynasd. May 12 22:00:40 ReadyNAS systemd-udevd[1682]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:40 ReadyNAS disk_event_handler[2012]: disk event handler called for add May 12 22:00:41 ReadyNAS disk_event_handler[2012]: Sending disk add event for /dev/sda to readynasd. May 12 22:00:41 ReadyNAS disk_event_handler[1993]: Sending disk add event for /dev/sdd to readynasd. May 12 22:00:41 ReadyNAS disk_event_handler[1988]: Sending disk add event for /dev/sde to readynasd. May 12 22:00:41 ReadyNAS systemd-udevd[1587]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1392]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1391]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1690]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1614]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[1390]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2091]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2092]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2093]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2095]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2096]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd-udevd[2094]: Process '/lib/udev/hdparm' failed with exit code 5. May 12 22:00:41 ReadyNAS systemd[1]: Started udev Wait for Complete Device Initialization. May 12 22:00:43 ReadyNAS systemd[1]: Mounted /data. May 12 22:00:43 ReadyNAS systemd[1]: Reached target Local File Systems. May 12 22:00:43 ReadyNAS systemd[1]: Starting Create Volatile Files and Directories... May 12 22:00:43 ReadyNAS systemd[1]: Starting LSB: Add to mtab the entry for /dev.... May 12 22:00:43 ReadyNAS systemd[1]: Mounting Apps Directory... May 12 22:00:43 ReadyNAS systemd[1]: Mounting Home Directory... May 12 22:00:43 ReadyNAS systemd[1]: Mounted Apps Directory. May 12 22:00:43 ReadyNAS systemd[1]: Mounted Home Directory. May 12 22:00:43 ReadyNAS systemd[1]: Started LSB: Add to mtab the entry for /dev.. May 12 22:00:43 ReadyNAS systemd[1]: Started Create Volatile Files and Directories. May 12 22:00:43 ReadyNAS systemd[1]: Starting Update UTMP about System Boot/Shutdown... May 12 22:00:43 ReadyNAS systemd[1]: Started Update UTMP about System Boot/Shutdown. May 12 22:00:43 ReadyNAS systemd[1]: Reached target System Initialization. May 12 22:00:43 ReadyNAS systemd[1]: Started Timer for ReadyNAS Update Service. May 12 22:00:43 ReadyNAS systemd[1]: Listening on D-Bus System Message Bus Socket. May 12 22:00:43 ReadyNAS systemd[1]: Started Timer for Debian Package List Updater. May 12 22:00:43 ReadyNAS systemd[1]: Started Daily Cleanup of Temporary Directories. May 12 22:00:43 ReadyNAS systemd[1]: Started Anti-Virus Definition Update Timer. May 12 22:00:43 ReadyNAS systemd[1]: Listening on RPCbind Server Activation Socket. May 12 22:00:44 ReadyNAS systemd[1]: Started Log Truncate Timer. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Timers. May 12 22:00:44 ReadyNAS systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Sockets. May 12 22:00:44 ReadyNAS systemd[1]: Reached target Basic System. May 12 22:00:44 ReadyNAS systemd[1]: Started Regular background program processing daemon. May 12 22:00:44 ReadyNAS cron[2179]: (CRON) INFO (pidfile fd = 3) May 12 22:00:44 ReadyNAS systemd[1]: Started MD repair service. May 12 22:00:44 ReadyNAS systemd[1]: Starting Login Service... May 12 22:00:44 ReadyNAS cron[2179]: (CRON) INFO (Running @reboot jobs) May 12 22:00:44 ReadyNAS systemd[1]: Starting Network bonding... May 12 22:00:44 ReadyNAS systemd[1]: Started WSD/LLMNR Discovery/Name Service Daemon. May 12 22:00:44 ReadyNAS wsdd2[2184]: starting. May 12 22:00:44 ReadyNAS systemd-udevd[2197]: Could not generate persistent MAC address for bond0: No such file or directory May 12 22:00:44 ReadyNAS kernel: bonding: bond0 is being created... May 12 22:00:44 ReadyNAS systemd[1]: Starting LSB: Startup script for the Logitech Media Server... May 12 22:00:44 ReadyNAS kernel: IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready May 12 22:00:44 ReadyNAS kernel: 8021q: adding VLAN 0 to HW filter on device bond0 May 12 22:00:44 ReadyNAS kernel: bond0: Setting MII monitoring interval to 100 May 12 22:00:44 ReadyNAS kernel: bond0: Setting xmit hash policy to layer2+3 (2) May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: al_eth_down May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: dma state didn't change to Disable May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: failed to change state, error -110 May 12 22:00:44 ReadyNAS systemd[1]: Started MD monitoring service. May 12 22:00:44 ReadyNAS kernel: bond0: Adding slave eth1 May 12 22:00:44 ReadyNAS kernel: configured MAC to RGMII mode: May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: using MSI-X per Queue interrupt mode May 12 22:00:44 ReadyNAS kernel: libphy: al mdio bus: probed May 12 22:00:44 ReadyNAS systemd[1]: Started D-Bus System Message Bus. May 12 22:00:44 ReadyNAS logitechmediaserver[2226]: Making sure that Logitech Media Server is not running first: No process in pidfile '/var/run/logitechmediaserver.pid' found running; none killed. May 12 22:00:44 ReadyNAS logitechmediaserver[2226]: Starting Logitech Media Server. May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md0 May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: phy[5]: device 18:05, driver Atheros 8035 ethernet May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:03.0 eth1: phy[5]:supported 2ef adv 2ef May 12 22:00:44 ReadyNAS kernel: bond0: Enslaving eth1 as a backup interface with a down link May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:01.0 eth0: al_eth_down May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: dma state didn't change to Disable May 12 22:00:44 ReadyNAS kernel: [eth rx] warn: failed to change state, error -110 May 12 22:00:44 ReadyNAS kernel: bond0: Adding slave eth0 May 12 22:00:44 ReadyNAS kernel: configured MAC to RGMII mode: May 12 22:00:44 ReadyNAS kernel: al_eth 0000:00:01.0 eth0: using MSI-X per Queue interrupt mode May 12 22:00:44 ReadyNAS kernel: libphy: al mdio bus: probed May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md1 May 12 22:00:44 ReadyNAS mdadm[2233]: NewArray event detected on md device /dev/md127
~ mdstat.log ~
"md127" can´t be found in the file.
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md1 : active raid6 sda2[0] sdc2[3] sdb2[2] sdd2[1] 1046528 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [UUUU] md0 : active raid1 sda1[4] sdd1[3] sdc1[2] sdb1[5] 4190208 blocks super 1.2 [4/4] [UUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Sun Apr 3 06:27:48 2016 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sun May 14 12:33:50 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Name : 119c1bce:0 (local to host 119c1bce) UUID : 2495045b:2aa5bd3c:8cff9bb5:de4e769c Events : 367 Number Major Minor RaidDevice State 4 8 1 0 active sync /dev/sda1 5 8 17 1 active sync /dev/sdb1 2 8 33 2 active sync /dev/sdc1 3 8 49 3 active sync /dev/sdd1 /dev/md/1: Version : 1.2 Creation Time : Sat Apr 30 23:31:42 2016 Raid Level : raid6 Array Size : 1046528 (1022.00 MiB 1071.64 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Mon May 8 01:08:11 2017 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Name : 119c1bce:1 (local to host 119c1bce) UUID : 2863873a:78baa761:890ee932:2551648e Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync /dev/sda2 1 8 50 1 active sync /dev/sdd2 2 8 18 2 active sync /dev/sdb2 3 8 34 3 active sync /dev/sdc2It seems that the RAID is ok, am I right?
Best regards
Kalle- jak0lantashMay 14, 2017Mentor
Somebody will have to look at the whole log archive, because it doesn't make any sense to me. Like mdgm-ntgr
You're not in a full root situation so the logs should be consistent, and they're not.
You don't find mention of md127 in dmesg.log, yet the logs I was aiming for are in systemd-journal.log (you said volume.log, but I believe you meant systemd-journal.log).
May 12 22:00:43 ReadyNAS systemd[1]: Mounted /data.Yet, you don't see md127 in mdstat.log. You really should see it there. "md127", "data-0", that's your data volume. If systemd-journal.log shows that md127 is started, then it should be in mdstat.log.
Also in the logs, there is lots of:
But I'm not sure what that means.
Your RAID array seems OK. The issue looks software to me. Or maybe an erroring HDD.
Hi,
you are right I meant systemd-journal.log not volume.log, my bad.
I´ve downloaded the logs a second time (as user "admin" on the webfrontend) and I can´t find "md127" or "data-0" in mdstat.log nor in the dmesg.log.
i don´t think it´s an erroring HDD, because right before the update all was O.K.
I will write mdgm and ask him if he can help me.
Thank you for your help.
Best regards
Patrice
