Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
jak0lantash
May 15, 2017Mentor
Not necessarily, no.
Let's wait for mdgm's feedback.
Kalle13
May 15, 2017Tutor
What do you mean?
I don't want to argue with you I am only curios.
Best regards
Kalle
- jak0lantashMay 15, 2017Mentor
I'm not arguing either :smileywink:
There are multiple reasons for the volume to appear "inactive", some of the most common:
- Full root: the volume dedicated to the system is completely full, preventing it from booting properly. In your case, it could be related to the process of updating the F/W (any F/W). Or some add-on that filled the volume and the consequence appeared after the reboot, as part of the update process.
- Corrupt system: often due to the previous condition, but also rarely occur without full root.
- Multiple disk failure: your drives could have been slowly dying but seemlessly "working", or suddenly died, or a mix. Updating a firmware implies writing to the drives which can trigger failure(s).
- Erroring disk: a disk can be flapping and cause the NAS to be enable to mount the volume.
- BTRFS corruption: any operation on the volume, even mount/unmount can lead to filesystem corruption if an unexpected event occur (at FS or HW level). It happens.
Etc.
It's a shame that the NAS doesn't show why is the volume inactive, in the GUI. It would reasonably easy to integrate it and really useful for anyone running into the issue, hence the post in the "idea" section.
- mdgm-ntgrMay 15, 2017NETGEAR Employee Retired
Not sure why it hasn't started. Would need a remote look to get more of an idea.
- Kalle13May 15, 2017Tutor
Hi,
just did it.
Best regards
Kalle
- Kalle13May 16, 2017Tutor
Hi,
thank you for your precise explanation jak0lantash. Just one day ago I didn`t thought that there were the slightest possibillity that your reasons can be the reason for my problem but now it`s sounds like I **bleep**ed up by my self, due to a dist-upgrade. :(
Best regards
Kalle - NASguruMay 16, 2017Apprentice
jak0lantash wrote:I'm not arguing either :smileywink:
Etc.
An excellent review of the reasons and for me the BTRFS seems to be the culprit.
- SandsharkMay 15, 2017Sensei
In a nutshell, loading the new OS version may have been the "last straw" in a series of events that caused the problem. So the new OS, in and of itself, may not be to blame. The new OS version itself may be a contributer if it does not tolerate a pre-exisitng problem as well as the previous version, or the simple process of doing an update (which uses space in the OS partition) may have been all it took.
There are also a couple posts in the idea exchange about better controlling OS partition problems (if that's what your issue is) that you may also want to up-vote.
Sandshark wrote:In a nutshell, loading the new OS version may have been the "last straw" in a series of events that caused the problem. So the new OS, in and of itself, may not be to blame. The new OS version itself may be a contributer if it does not tolerate a pre-exisitng problem as well as the previous version, or the simple process of doing an update (which uses space in the OS partition) may have been all it took.
This makes sense given I had a pre-existing error prior to upgrading from 6.6.1 to 6.7.1.
Not sure from the logs why it's not mounting. The logs show:
May 14 19:55:19 ReadyNAS start_raids[1041]: mdadm: device data-0 exists but is not an md array.
The disks appear to be healthy from looking at smart_history.log, but the RAID hasn't started.
