Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
Kalle13
May 15, 2017Tutor
What do you mean?
I don't want to argue with you I am only curios.
Best regards
Kalle
jak0lantash
May 15, 2017Mentor
I'm not arguing either :smileywink:
There are multiple reasons for the volume to appear "inactive", some of the most common:
- Full root: the volume dedicated to the system is completely full, preventing it from booting properly. In your case, it could be related to the process of updating the F/W (any F/W). Or some add-on that filled the volume and the consequence appeared after the reboot, as part of the update process.
- Corrupt system: often due to the previous condition, but also rarely occur without full root.
- Multiple disk failure: your drives could have been slowly dying but seemlessly "working", or suddenly died, or a mix. Updating a firmware implies writing to the drives which can trigger failure(s).
- Erroring disk: a disk can be flapping and cause the NAS to be enable to mount the volume.
- BTRFS corruption: any operation on the volume, even mount/unmount can lead to filesystem corruption if an unexpected event occur (at FS or HW level). It happens.
Etc.
It's a shame that the NAS doesn't show why is the volume inactive, in the GUI. It would reasonably easy to integrate it and really useful for anyone running into the issue, hence the post in the "idea" section.
