Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
Kalle13
May 15, 2017Tutor
Hi,
yes I did it several months ago. I totaly forget about that. I did it because I do that on my other linux maschines, simple as that. That was not the smartest move. After this dist-upgrade I had big problems with the NAS and I had to do a Firmware reset. Seemingly there are also leftovers from this action. S h i t !
Best regards
Kalle
