Kalle13
May 13, 2017Tutor
After upgrading to 6.7.1 on RN214 no volumes can be loaded
Hello, I just installed the new upgrade 6.7.1 on my RN214 and got the confusing message that my volumes can`t be loaded. It`s the same problem others have: ReadyNAS 516 just upgraded to 6.7....
- May 19, 2017
You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.
Kalle13
May 18, 2017Tutor
mdgm wrote:Looks like you did some stuff via SSH e.g. a dist-upgrade using apt-get. Why did you do that?
What did you found exactly and where did you found it? I want to look at it. Sorry for my hastiness but I must get that NAS going.
There are very important papers on it. I need them for my studies. :(
Best regards
Kalle
mdgm-ntgr
May 19, 2017NETGEAR Employee Retired
- Kalle13May 19, 2017Tutor
mdgm wrote:You could perhaps try ReadyNASOS 6.7.3-T283 (Beta 1)
There's a fix in there for one possible reason why a volume may not mount. I wonder if you ran into that.Hi,
thank you for the tip! But I am not that resolute to do that beacuse it`s a BETA. Probably it would work if I reinstall the OS!?
Just like this:
Best regards
Kalle - StephenBMay 20, 2017Guru - Experienced User
I'd try the beta myself.
Your other option is to try paid support (my.netgear.com)
- Kalle13May 20, 2017Tutor
StephenB wrote:I'd try the beta myself.
I think that`s the way: First I will try the beta. If this don`t work I will have a look on the apt-get logs. Hopefully I find the failure there. In the end if this all don`t work I have to conctact the support.
Best regards
Kalle
