cmajewsk
Apr 12, 2012Aspirant
Any Sparc-based respect in here?
I have an ReadyNas 600 still chugging along nicely. However, I am in need of some options for a hard drive upgrade. Looking for a couple of 2GB (or higher if supported) drives. Can anyone recommen...
cmajewsk
mdgm wrote: Disks on the list for the NV+ (v1) not the v2.
The NV+ (v1) is Sparc.
Perhaps get the Hitachi.
Thank you for the quick reply. Which Hitachi do you recommend? Also, Hitachi over Seagate or WD? I have never used them.
Again, thank you for your support!
- Jan 01, 2016Retired_Member
