cmajewsk
Apr 12, 2012Aspirant
Any Sparc-based respect in here?
I have an ReadyNas 600 still chugging along nicely. However, I am in need of some options for a hard drive upgrade. Looking for a couple of 2GB (or higher if supported) drives. Can anyone recommen...
mdgm-ntgr
Apr 12, 2012NETGEAR Employee Retired
cmajewsk wrote:
Thank you for the quick reply. Which Hitachi do you recommend?
Depends what you're after. Get the DeskStar if you want a desktop drive or the UltraStar if you want an Enterprise drive.
cmajewsk wrote:
Also, Hitachi over Seagate or WD?
Yes.
- Jan 01, 2016Retired_Member
