oct
Mar 28, 2014Follower
APC BR1000G Back-UPS Pro 1000 compatible with ReadyNas Duo
Sold on amazon.com as "APC BR1000G Back-UPS Pro 1000 Uninterruptible Power Supply", it is compatible with ReadyNas Duo V1.
It shows "APC Back-UPS RS1000G, Battery charge: 100%, 50 minutes OK" on the NAS.
- bitondaAspirantHi
looking in the web interface readynas duo V1 (rnd2150v1) seems to be compatible only with network UPS, do you confirm that ReadyNAS duo V1 has also USB support ? I cannot find any reference in the manual. Thanks - NhellieVirtuosoYes the duo has support for USB UPS. As stated on its FaQ:
http://kb.netgear.com/app/answers/detai ... s-duo-faqs - bitondaAspirantHi
sorry but at that link I cannot find any faq items describing such as compatibility , mine is a old readynas duo v1
thanks - StephenBGuru - Experienced UserThe duo v1 definitely supports USB connected UPS. I have used it with CyberPower products, but not with APC.
Netgear does not keep UPS compatibility lists, you are limited to what from customers post in this forum. - bitondaAspirantThanks StephenB, did you remember which model from CyberPower ? we need to buy the right supported, UPS Thanks
- StephenBGuru - Experienced UserI think any of the current models would work, but I was using a CP1350AVRLCD (which is still available).
It's bigger than I needed for the duo, but I had other equipment I connected as well. The CP1350AVRLCD is still in service, but connected to my RN102 at the moment (and networked to the duo and my NV+). - bitondaAspirantThanks Stephen so much, i wrote to cyberpower asking for a small sized ups compatible with your one. If they answer me i will post their suggestions. Thanks
