beefy314
Aug 09, 2011Aspirant
APC UPS + Readynas Ultra + Synology?
Is there anyway to connect these devices together? I currently have a ReadyNAs Ultra 2 and a synology DS211j. I'm planning to get an APC UPS with usb port. I'm assuming APC has only one usb port bu...
mdgm-ntgr
Aug 09, 2011NETGEAR Employee Retired
There's no need to use SSH on the ReadyNAS side. The relevant settings will show under System > Power e.g. when the UPS is connected.
You'd have to ask Synology as to whether they use NUT and support sharing a UPS over a network. If they do then this should work well.
