beefy314
Aug 09, 2011Aspirant
APC UPS + Readynas Ultra + Synology?
Is there anyway to connect these devices together? I currently have a ReadyNAs Ultra 2 and a synology DS211j. I'm planning to get an APC UPS with usb port. I'm assuming APC has only one usb port bu...
beefy314
This is what I found on their website.
"Connect an uninterruptible power supply (UPS) to your DiskStation to prevent data loss from unexpected power failure. DSM also allows multiple Synology DiskStations in the same network to share one UPS. With only one Synology DiskStation connected to the UPS, other Synology DiskStations within the same network may also be protected under the same configuration."
Is this it? on the web gui of my synology there's an option asking for "Network UPS IP"
Where will the APC get its IP address if the data port connects to the usb of the ReadyNAS?
Thanks mdgm
Thanks mdgm
