beefy314's avatar
beefy314
APC UPS + Readynas Ultra + Synology?
Is there anyway to connect these devices together?
I currently have a ReadyNAs Ultra 2 and a synology DS211j. I'm planning to get an APC UPS with usb port. I'm assuming APC has only one usb port but both my servers support USB UPS monitoring.
What does Monitor UPS over SNMP mean on the frontview of the Ultra 2?
Also can I attach the synology to the UPS and the usb of the Ultra 2 to the Synology?
Thanks
  • What the Synology is asking for is the Network IP of the NAS that is connected to the UPS, not the UPS itself (it is not really part of the network). Once you connect the UPS to the Ultra it should show up in RAIDar, and mousing over the UPS button (now green) will show the status of the UPS charge.
  • Thanks guys!
    So when setting this up, I assume that the router has to be plugged to the ups as well?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Yes. Otherwise when the power goes out one NAS won't receive the alert to shutdown and will shutdown unsafely.
ProSupport for Business
