gpwolfe
Nov 30, 2010Aspirant
Boo-Yah! 8GB (2x4GB) works in pro.
Greetings,
I just wanted to say that the pro (rndp6000) works w/4GB DIMMs.
Specifically, at least, these:
DDR2 8GB (2x4GB) PC6400 800MHz PATRIOT PSD28G800K
Frontview shows:
Firmware: RAIDiator 4.2.15
Memory: 8064 MB [6-6-6-18 DDR2]
I booted the thing just to see if it'd recognize any of it and grab some logs. Now it's running the memory test. I'll let that go overnight.
I was reticent to try it as no one else on here seemed to think it would work. I looked up the stats on the Q963 controller and ran a few information gathering tools like:
And after seeing this:
I figured since it claims to support 4GB modules it was worth a shot.
Here's the 'meat' from decode-dimms with the new memory installed.
Here's
Not certain what else anyone might want for added 'warm and fuzziness' to take the plunge.
On another note, the corsair XMS2 twin2x4096-6400c5c did not work for me contrary to many other posts claiming they do. I will qualify that a bit further by stating that I could not get either DIMM to boot in the first socket. The one closest to the cpu. If I put one in the other socket and nothing in the one closest to the cpu it booted fine. If I left the 1GB stock in its shipped socket (closest to the cpu) and put one of the corsair modules in other socket it would boot and show ~3GB - 128MB (shared video ram reservation?).
In any case I robbed some memory out of my son's machine. A pair of supertalent T8UB2GC5 modules also DDR2-800 PC6400. They show up as [4-5-5-15 DDR2] in frontview.
I hope that's helpful.
Thanks,
--Gary
Frontview shows:
dmidecode
hwinfo
decode-dimms (After building and inserting the eeprom module)
lshw
Memory Controller Information
Error Detecting Method: 64-bit ECC
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 4096 MB
Maximum Total Memory Size: 16384 MB
Supported Speeds:
Other
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 4
0x0009
0x000A
0x000B
0x000C
Enabled Error Correcting Capabilities:
None
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0050
Guessing DIMM is in bank 1
---=== SPD EEPROM Information ===---
EEPROM Checksum of bytes 0-62 OK (0x34)
# of bytes written to SDRAM EEPROM 128
Total number of bytes in EEPROM 256
Fundamental Memory type DDR2 SDRAM
SPD Revision 1.2
---=== Memory Characteristics ===---
Maximum module speed 1600MHz (PC12800)
Size 4096 MB
tCL-tRCD-tRP-tRAS 6-6-6-18
Supported CAS Latencies 6, 5, 4
Minimum Cycle Time (CAS 6) 2.5 ns
Maximum Access Time (CAS 6) 0.4 ns
Minimum Cycle Time (CAS 5) 3 ns
Maximum Access Time (CAS 5) 0.45 ns
Minimum Cycle Time (CAS 4) 3.75 ns
Maximum Access Time (CAS 4) 0.5 ns
---=== Manufacturing Information ===---
Manufacturer Patriot Memory
Manufacturing Location Code 0x02
Part Number PSD24G8002
Manufacturing Date 2010-W38
Assembly Serial Number 0xB2151B28
Decoding EEPROM: /sys/bus/i2c/drivers/eeprom/0-0052
Guessing DIMM is in bank 3
SPD Revision 1.2
Size 4096 MB
Assembly Serial Number 0xC9131B28
Here's
hwinfo --memoryoutput:
01: None 00.0: 10102 Main Memory
[Created at memory.61]
Unique ID: rdCR.CxwsZFjVASF
Hardware Class: memory
Model: "Main Memory"
Memory Range: 0x00000000-0x1f3791fff (rw)
Memory Size: 8 GB
Config Status: cfg=new, avail=yes, need=no, active=unknown
Thanks,
--Gary
- ianmacdAspirant
ianmacd wrote:
The time has come for me to purchase my third ReadyNAS and, naturally, more is better, so I'm looking at the RNDP6630-200EUS, the 18 Tb Pro 6.
The new 18 Tb Pro 6 arrived during the week, as did my Patriot PSD28G800K memory, which I had to purchase from a shop in Ireland, because I couldn't find that model in the Netherlands.
My new beast is up and running after 7 successful passes through the memory check.
My only complaint with this unit so far (if you can even call it that) is that the Seagate ST33000650NS drives that came with it are unbelievably noisy. The unit is in the cupboard under the stairs, so it doesn't matter in my case, but you really wouldn't want this box anywhere near you while you're working. - As I will be purchasing a new diskless Readynas Pro 6 shortly, can those who have posted on this thread confirm that the following ram will
work on this unit:
Patriot Signature 4GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model PSD24G8002
Thanks guys.
:D spiderman wrote: As I will be purchasing a new diskless Readynas Pro 6 shortly, can those who have posted on this thread confirm that the following ram will
work on this unit:
That's the model that I use and it has been running great. I haven't tried running just one stick though. Is that what you plan to do?
If so, I can remove 1 stick and give it a whirl.the model that I use and it has been running great. I haven't tried running just one stick though. Is that what you plan to do?
No, I want to install the full 8 gb.
I'll let everyone know on the thread how it works once I get the unit and set it up.
Thanks for replying.
:D- Nice! Look forward to your followup.
You'll like the Pro-6. You plan to use your older Pro as a backup?
Post Posted: Mon Aug 29, 2011 5:22 pm
I would like to run ESXi datastores and the Java VM Virtual Box on the PRO 6 and use my PRO as a multi-media file server.- jmirabilAspirant
fbmachines wrote: spiderman wrote: As I will be purchasing a new diskless Readynas Pro 6 shortly, can those who have posted on this thread confirm that the following ram will
work on this unit:
SUCESS REPORT:
I can report on my Pro Business Readynas I just completed a 4-->8Gb Readynas changeover in RAM, and I noticed my NAS with WD30EZRS drives is a bit snappier with 8Gb than 4Gb. I used two of the PSD24G8002 Patriot memory sticks like above... I had two 2Gb Adata blue memory modules in there with aluminum shields from Egghead before, I might try those memory sticks in my buddy's Readynas Ultra 6 w/ low power Atom dualcore processor.
I too would like to try running ESXi datastores and the Java VM Virtual Box on my Readynas pro business and use my PRO as a multi-media file server, probably a Conroe 2.4Ghz dualcore upgrade (E6600) from the E2160 might help also, but dont want to violate my warranty... Any advice for virtualbox or ESXi? I'd love to know here or via a PM. Thanks! - mdgm-ntgrNETGEAR Employee RetiredThe Pro Business (RNDP6000-100) has a CPU that doesn't have VT-x so you can't run 64-bit VMs using VirtualBox. You can use it as an ESXi datastore for 64-bit VMs though.
3rd party memory upgrades are not supported, neither is installing stuff like VirtualBox.
CPU upgrades do void the warranty and not all work (can be incompatible or cause overheating etc.). If you want to try a CPU upgrade search for CPU upgrades that others have done). Instead of doing a CPU upgrade it would be much better to sell a Pro Business (RNDP6000-100) and get a Pro 6 (RNDP6000-200). - jmirabilAspirant
mdgm wrote: The Pro Business (RNDP6000-100) has a CPU that doesn't have VT-x so you can't run 64-bit VMs using VirtualBox. You can use it as an ESXi datastore for 64-bit VMs though.
I see, you're referring to the E2160 native CPU - well I guess I'll have to decide whether I want to void my warranty to get the VT-x available with the Conroe 2.4G dualcore E6600 CPU...
decisions decisions... I've read else where in the forums that memory upgrades will not violate warranty if they pass tests and are done responsibly and properly. I kept my original 1Gb of RAM so that will always be available if I need to downgrade memory (thats easy, just take out 2 screws and click in and out memory modules with an antistatic wrist-strap in place) but I'm not going to tinker with a CPU and the RDNP6000-200 is a better idea for that indeed. I bet someone has gone with an E6600 (and said forget the warranty...) and made this Virtualbox and ESXi VM datastore both work though...
FYI:
http://ark.intel.com/products/27250/Int ... MHz-FSB%29
this notes that the E6600 has VT-x... time to decide.. My Pro Business still has 4 more years of warranty...I dont think I want to lose that...
Good suggestion on the Pro 6 -- I tried 2x to order (order then reorder) a Pro 6 refurb from these guys when they CLEARLY showed stock (I screen-captured it 2x) :
http://compu-america.com/index.php/rndp ... -serv.html
but they are disreputable dirtb@gs and they never honor their prices nor availability for me (nor I suspect others too..) and I have a BBB complaint pending with them. - ReadyNAS Pro 6 arrived today. I haven't actually opened it up yet but I've checked the box to make sure it's the RNDP6000-200 not the Ultra or Pro Business Edition :).
Now I'm sure it'll be fine as it is, but when I’ve had it a while and the upgrade itch needs scratching...
RAM. Is it really picky on which RAM it'll take? I see Patriot PSD24G8002 and Patriot PSD28G800K mentioned in this thread, but would it need to be them? Or would any 2x 4GB DDR2 800MHz PC2-6400 240-Pin DIMM work?
