Palle1
Sep 04, 2012Follower
Brother HL-2070N doesnt show up on RedayNAS Duo V2
Connected Brother HL-2070N to readynas Duo V2. Doesnt show up - neither in Duo's dash bord or W7 net work resources. What could be wrong - how to fix? Printer works fine when connected directed to...
PapaBear1
Sep 04, 2012Apprentice
Palle - according to the information I can find, the HL-2070N is a network capable printer, hence the "N" at the end. All you would need to connect it to your network is an ethernet cable, so why would you want to use the Duo v2 as a print server? Directly connecting a printer to the network is a far better solution.
