maduhbee's avatar
maduhbee
Follower
Feb 23, 2015
Can I use 8TB drives in my 104
Ready NAS 104 and Synology DS213 user.
DS213 has been running for > 2 years w/o issue.
Just got the 104 to expand storage. I saw these Seagate 8TB drives for less than $300 a pop. Planning on Running RAID 10. (16TB total) Will this work?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The 104 supports volumes up to 16TB in capacity so RAID-10 should work. However we don't have any 8TB disks on the compatibility list and I'm not sure how well/badly those drives are suited to RAID use.
    Welcome to the forum!
    mdgm-ntgr
    One thing I should add is that some high capacity disks are designed a bit differently to most disks and may not fit in the drive trays. That is another thing to consider in addition to the disk not being on the compatibility list.
ProSupport for Business
