mrhoads
Jan 07, 2012Aspirant
Can not check for update
"Check for update" doesn't work. I have clicked on it many times and waited overnight but nothing happens. I got an email with the directions and that I needed to update but no luck. :oops:
mrhoads
Jan 08, 2012Aspirant
All looks ok.
mdgm wrote:
What version of RAIDiator and what web browser are you using?
4.3 Can not download the new version.
Have you tried clearing your web browser cache?
Yes
Have you checked that your settings under Network in Frontview are correct? Particularly you should check the DNS and Gateway settings.
- Jul 31, 2022Retired_Member
