JohnB52's avatar
JohnB52
Can't connect to ReadyNAS 102 to Virgin Hub 3.0
I changed my old Virgin Media Router for a Hub 3.0 on a LAN set up with TP Link Powerline adaptors.   The network works fine with all devices on the network except the NAS 102. The PC on the Networ...
  • StephenB's avatar
    Oct 27, 2016
    Did you set up the RN102 initially?
    Usually this problem occurs when (a) someone assigned a "static" IP address to the ReadyNAS and (b) you then change routers.  Your router uses a specific range of IP addresses (usually 192.168.0.x or 192.168.1.x) and if your old router used a different range from the new one, you end up with this issue.
    First confirm that it is an issue with the IP address.  You can do that downloading RAIDar 6.1 from here: http://kb.netgear.com/app/answers/detail/a_id/20684#raidar  RAIDar should be able to find your ReadyNAS even if it is using an incompatible IP address.  If RAIDar finds the NAS, post back the ReadyNAS IP address here.  Also post your PC's local IP address.  If you have a windows PC, this guide should help you find its IP address: https://support.microsoft.com/en-us/help/15291/windows-find-pc-ip-address
    These addresses are safe to post, but if you feel uncomfortable you can send me a PM.
    Assuming it is an IP address problem, one way to solve it is to change the router IP address range to match the address range used by the old router.
    However, you need the NAS admin password anyway.  You do this with an OS reinstall, which will reset the IP address setup to "automatic" and also resets the admin password to password.  This likely will solve both your issues.  The procedure is described on pages 19-20 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf.  It is a bit tricky, since the paper-clip needs to be inserted in the back of the NAS, and the navigation to the right boot option is done using the buttons on the front.  Be very careful not to do a factory default, as that will wipe your data.
    JohnB52 wrote:
    They claim that they need to get into Netgear NAS Admin to fix the problem.
    It's quite unusual for an ISP tech person to be willing to go into the NAS at all.  Personally I wouldn't let them into my ReadyNAS though.
ProSupport for Business
