demusss1
Aug 11, 2011Aspirant
Changing Fan in ReadyNAS ultra 4+ PSU
I've had a ReadyNAS ultra 4+ for a couple of weeks and found the fans to be a bit noisy. I've already changed the main 92mm one for a 120mm. Its helped a bit but I think the the main was actually ...
demusss1
Aug 12, 2011Aspirant
The PSU is buried below the drives so you can't see the fan unless you take the unit apart.
I'll take some photos this weekend and post them.
Are you saying that the Ultra 4+ PSU is normally fanless? and the only fan in the whole unit is the 92mm on the back?
Cheers
Anthony
Cheers
Anthony
