demusss1
Aug 11, 2011Aspirant
Changing Fan in ReadyNAS ultra 4+ PSU
I've had a ReadyNAS ultra 4+ for a couple of weeks and found the fans to be a bit noisy. I've already changed the main 92mm one for a 120mm. Its helped a bit but I think the the main was actually ...
claykin
Aug 12, 2011Aspirant
demusss wrote:
Are you saying that the Ultra 4+ PSU is normally fanless? and the only fan in the whole unit is the 92mm on the back?
Yes. Unless Netgear made a production change.
Keep in mind when changing fans you must make sure the CFMs are the same or better than Netgears OEM fan.
