demusss1
Aug 11, 2011Aspirant
Changing Fan in ReadyNAS ultra 4+ PSU
I've had a ReadyNAS ultra 4+ for a couple of weeks and found the fans to be a bit noisy. I've already changed the main 92mm one for a 120mm. Its helped a bit but I think the the main was actually ...
demusss1
Aug 12, 2011Aspirant
claykin wrote:
Yes. Unless Netgear made a production change.
Keep in mind when changing fans you must make sure the CFMs are the same or better than Netgears OEM fan.
Then Netgear have made a production change then.
I've found details online about the fan but not the CFM. I'll post a link wth the pictures.
