demusss1
Aug 11, 2011Aspirant
Changing Fan in ReadyNAS ultra 4+ PSU
I've had a ReadyNAS ultra 4+ for a couple of weeks and found the fans to be a bit noisy. I've already changed the main 92mm one for a 120mm. Its helped a bit but I think the the main was actually ...
claykin
Aug 12, 2011Aspirant
Surprising! Why they went with a 120W PSU that requires a fan when the NVX has a 220W with no fan is surprising. Maybe the extra heat of the Atom CPU did not allow for enough cool air inside the box.
Maybe a Jedi can chime in.
