demusss1
Aug 11, 2011Aspirant
Changing Fan in ReadyNAS ultra 4+ PSU
I've had a ReadyNAS ultra 4+ for a couple of weeks and found the fans to be a bit noisy. I've already changed the main 92mm one for a 120mm. Its helped a bit but I think the the main was actually ...
demusss1
Aug 13, 2011Aspirant
Thinking about it, replacing the fan with another small one running at full pelt is probably also going to be noisy.
Has anyone used a standard ATX power supply on these? I know theres going to be some differences because the Ultra4 doesnt use negative voltages, but with a bit of rewiring it should be possible.
Might be easier to just hide it in a cupboard and let it whir away to itself.
btw the sticker on the back doesnt mention anything about voiding the warranty.
Anthony
Anthony
