machefi
Nov 01, 2016Aspirant
Connection problems after update 6.6.0
After updating to version 6.6.0 adminiastratora page loads without problem and works even faster. I do not know whether an update is causing the problem. However, on a local network storage is no longer visible. It appears as a multimedia device, but the connection is not possible. The same effect on the PC with Windows 7 and Smart TV. I do not know if it's important: I did not change protocols for folders in the 'Shares'. They are set to SMB and DLNA. I checked the 'System> Settings> Services', there SMB indicator is inactive. I can not change its settings active. ReadyDLNA is active. Application SMB Plus is installed. What should I check in the settings ReadyNAS that was again available in the local network? I'm not an expert in computers and my English is not the best, I'm sorry for that.
- machefiAspirant
Thanks for the advice. I could not find email support, telephone is paid - my English is a little weak. It remains to me to wait, and once again review the FAQ. Maybe someone remedy or another update to change it ...
Have a nice day.- StephenBGuru - Experienced User
Did you look in the Windows credentials manager of your PC?
The idea is to remove any credentials there for the NAS, and to create new ones using a username/password for an account on the NAS. The NAS admin account can be used if you have no user accounts there.
- meinokramerAspirant
hi ,i cant reach the nas with windows explorer after update to 6.6.0.
dlna works well,and the main site with http works also.
the error calls ...''the nas has a wrong name ,check the networks on problems.''
grtz meino
grtz meino
Did you try accessing it by both its IP address and its hostname?
Also, look in settings->services and check that SMB is turned on. Also check that SMB is still enabled for each share.
yes ,,both done.
i can see my nas in windows network but when i will access the nas the error appears.
''controleer spelling van de naam ,er is anders een probleem met het netwerk''(dutch)
check the spell of the name,otherwise there 's a problem with the network
grtz meino
