Spetsdod
Nov 07, 2016Tutor
Difference between RN526XD3 and RN526XE3
So, I see the difference between the two models is desktop vs enterprise disks, but can someone please help me understand the difference between those disks? Reliability? Speed? This is going i...
Nov 07, 2016Guru - Experienced User
Spetsdod wrote:
I mean if I just buy the diskless 526 and drop in 6 Western Digital Red drives x 3TB, that ends up being almost $300 less than just buying the desktop RN526XD3 at 6x3TB.
I am with you here, and have always purchased diskless models myself. Then I choose the disk models I want, and generally save money as well.
On the other side of the argument - if you buy D3 or E3 models, then the disks are warranted by Netgear to be compatible with the NAS. Netgear also handles any warranty returns of the drives.
Also, some large disk drives don't have mounting holes in the right place for ReadyNAS. Netgear won't pick them, but you might inadvertantly buy them. Some folks end up modifying the drive trays to get them to fit - something to avoid in my opnion.
One clear difference is warranty. Enterprise disk warranties are almost always 5 years, desktop warranties are three years. The includes D3 and E3 ReadyNAS models - though they are not yet listed in the KB article- http://kb.netgear.com/app/answers/detail/a_id/26066/~/readynas-support-and-warranty
Enterprise drives generally run at 7200 rpm, and are designed for 24-7 use. They have more sophisticated vibration management than pure desktop drives (since they are intended for disk arrays). They can be noisy, and they can run fairly hot in a ReadyNAS.
Desktop drives (particularly the larger sizes) tend to be 5400-5900 rpm, and are designed for ligher workloads. They often are missing some features like TLER which are useful for RAID.
NAS-purposed drives are somewhere in between. They have features likeTLER and some vibration management built in. They run in the 5400-5900 speed range, and run at lower temperatures in a NAS than enterprise disks. They often are quieter than enterprise disks. Your WDC Reds are NAS-purposed.
Personally I split the difference and go with NAS-purposed drives (WDC Reds are my preference, but I have no quarrel with folks who go with Seagate Ironwolf).
c3po
Nov 09, 2016NETGEAR Expert
Just a note that we added two more mounting holes on desktop disk tray.
Although we have not modified tool-less tray plastic bracket to make it compatible with all drives yet, the tray is compatible with all drives using bottom screw mounting holes.
The drawback is that it is no longer tool-less when screws are needed. We will make the tray tool-less again in future.
(For newer large capacity drives without middle side moutning holes and 2.5" SSD drives, need to take out plastic bracket from tray and mount drive with screws)
