Karas007's avatar
Apr 17, 2017
Discs from Readynas Ultra 4 Plus to Ultra 6
Hello,
I Have Readynas ultra 4 plus(RAIDiator 4.2.28) with 4 disks but motherboard died I would like to get my data back so I bought Readynas Ultra 6 and want to put my disks from ultra 4 plus to ultra 6. My question is it will run without format and I will see all my data just like I will run mine old machine? Or I need to do some additional things to run it without any issues?
Thank you for your help
  • StephenB's avatar
    You can simply migrate the disks.
    The only caveat is that if the Ultra-6 is running different firmware, then it will attempt to upgrade (or downgrade) the disks to match what's in its flash. If the firmware happens to be close that won't matter - but if it is very old, it could be a problem.
    If you have a spare disk (not part of the array), you could try doing a factory reset on the ultra-6 with only that disk in place.  Then install 4.2.28 firmware on the NAS.  After that, power down, remove the spare, and migrate the disks.
    • Karas007's avatar
      Karas007
      Tutor
      Thank you StephenB,
      is there any way how to check firmware ver. without insertink spare HDD? It will run if I will turn on NAS and go into Admin page?
      Thank you
      • StephenB's avatar
        The firmware version might show up briefly on the LCD if you boot diskless - worth a try anyway.
        I don't think RAIDar will show it to you either (I think it just says "no disks").  But that's worth a try too.
        Let us know if either does the trick.
ProSupport for Business
