Mike_Spin
Sep 27, 2021Aspirant
Disk not detected in ReadyNAS 4220
Hoping someone could help me out. We have a ReadyNAS 4220 which had a failed disk, we have replaced the disk but it is not being detected. The web interface just shows a empty slot. I have rebooted t...
Sandshark
Sep 27, 2021Sensei
Well, bad drives straight from the manufacturer do happen, so you may need to test the drive in a PC using WD's Data Lifeguard. I always test my drives even before I install them. Did you do the replacement with power on or off? Does the log show the removal of the old drive? Does the Volume page show the bay empty and nothing is shown for that slot on the Performance page?
If you did it with power off, try removing the drive with power on and re-insert it. If that does nothing, try re-booting the computer again. If that doesn't fix it, then most likely either it wasn't the drive in the first place that failed, but the NAS, or the drive came to you bad. So test the drive.
If you have a scratch drive that's smaller (to insure it doesn't get added to the array), then you can try adding that just to see if it's detected.
Mike_Spin
The drive was replaced whilst powered on, we did the same for another failed disk on Friday and that one worked fine. We have tested with another new disk and that one is also not detected, the bay is showing empty under Volumes and not disk showing under performance in the GUI. I will see if we have a dock to test the disk and go from there.
- SandsharkSep 27, 2021Sensei
Two unrecognized drives does not bode well for the slot. They are SATA drives, not SAS, right? I don't recall if the 4220 will physically accept a SAS drive, but it definately can't handle them. Check to see that there doesn't seem to be any damage to the SATA connector or debris in it. And while you are checking the new drive, check the old one. If it's actually good, then that's a very bad sign with regard to the slot itself.
- Mike_SpinSep 28, 2021Aspirant
Yep both SATA disks, connectors have all been checked and no signs of any damage, dust or debris. Got the new disk be shipped to our office for testing and getting quotes for a new NAS.
