jedas's avatar
jedas
Disk spin-down problem, RN104, fw 6.2.0
Hello,
I'm using RN104, 2 x 4GB WD RED in JBOD/Flex mode (I need no raid). No apps installed, samba, dlna services stopped to debug this issue. Http/https/ssh - enabled. I've enabled disk spin down after 5 minutes from GUI menu. System logs shows that disks are stopped, but then immediately started after 4-8 seconds.
Disk [0] going to standby...
Disk [0] spinning up...
After enabling write log: echo 1 > /proc/sys/vm/block_dump I see this in the dmesg:
md0_raid1(694): WRITE block 8 on sda1 (1 sectors)
md0_raid1(694): WRITE block 8 on sdb1 (1 sectors)
jbd2/md0-8(719): WRITE block 3684640 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684648 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684656 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684664 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684672 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684680 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684688 on md0 (8 sectors)
jbd2/md0-8(719): WRITE block 3684696 on md0 (8 sectors)
leafp2p(1282): WRITE block 775816 on md0 (8 sectors)
I do believe, these writes wakes up the disks, becaue they happen in every 4-8 seconds. I've tried to kill leafp2p process, it doesn't seem to be the problem source. I can suspect that it's these writes are made by kernel, but don't have any knowledge about raid stuff. Same behaviour is when I type "hdparm -y /dev/sda". It spinds down, and wakes up in a second. Please advise.
ProSupport for Business
