BALR1415
Jul 21, 2011Aspirant
Disk tray for ReadyNAS Duo
I received a ReadyNAS RND2150-100NAS as part payment for some work. It however does not have any disks or disk trays. I used a loaned disk to test it and it seems fine. Searching this forum I beleive ...
PapaBear1
Jul 22, 2011Apprentice
If when you get the trays, if they don't include the screws, for a temporary fix you can rob some of the small flathead screws holding the side panels on, and the back plate on. The drives are ok with just two screws in a diagonal pattern. (That hint of only two screws came from a Jedi who mentioned they do that in the lab when testing drives).
Then ask Netgear for some. If they are unwilling to send some, post back.
