BALR1415
Jul 21, 2011Aspirant
Disk tray for ReadyNAS Duo
I received a ReadyNAS RND2150-100NAS as part payment for some work. It however does not have any disks or disk trays. I used a loaned disk to test it and it seems fine. Searching this forum I beleive ...
mdgm-ntgr
Jul 25, 2011NETGEAR Employee Retired
So it's a tray with the old design (circular button)? There's a guide to releasing a stuck tray here: http://www.readynas.com/kb/faq/hardware/how_can_i_release_a_stuck_disk_tray
If you the disk tray broke when you attempted to release it contact NetGear technical support and they should be able to arrange a replacement.
