JarleH
Jan 12, 2012Aspirant
Disks for NV+ V2?.. More disks needed on comp list...
Which one of these drives do you guys suggest? The WD drive has more cache... The prices are the same, so money is not a factor. What is important is speed and reliability! jarle
mdgm-ntgr
Jan 12, 2012NETGEAR Employee Retired
Oops. I missed that. You're right.
Both are good choices as they're on the compatibility list.
There may be a small difference in speed depending on which disk you use, but not very much between two 5400RPM disks.
