vasketsov_serg
Dec 01, 2017Aspirant
Does ReadyNAS 214 support HGST Ultrastar He10 HUH721010ALE604 with Power Disable feature (0F27454)
Hi! HGST Ultrastar He10 HUH721010ALE604 has 2 partnumbers: 0F27606 -Without Power Disable feature 0F27454 -With Power Disable feature Does ReadyNAS 214 support both items or only 1st hdd? ...
- Dec 06, 2017
Hi vasketsov_serg!
WD101KRYZ is listed in HCL for RN214 and basing on the WD spec sheet this drive does not support Power Disable Feature.
It would still be better if you can get in contact with WD support regarding part numbers since it does not show on their spec sheet as well and to verify if PD is a feature for this model.
I hope this helped you.
Regards
Marc_V
Dec 03, 2017NETGEAR Employee Retired
Hi vasketsov_serg!
RN214 became available before SATA III rev 3.3 came out wherein the support for Power Disable feature is part of the revision. Other revisions do not support it as per HGST information on Power Disable feature where the HDD might not spin or get stuck due to Pin3 providing power. SATA III for RN214 might be on rev 3.1 or 3.2 (We can try to check this info) where HGST drives with Power Disable feature is not supported. It would be best if we also wait for other forum users who have this information share it with us.
To answer your question, the HDD without Power Disable Feature is supported and listed on HCL but the latter is not yet tested or might not be compatible at all.
Regards
- vasketsov_sergDec 06, 2017Aspirant
Thank you, Marc_V!
- Marc_VDec 06, 2017NETGEAR Employee Retired
Hi @veasketsov_serg!
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped you with your concern or if you need further assistance.
We encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved or provided you the correct information and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Sorry.
I'd like to ask about Western Digital WD Gold 10 TB (WD101KRYZ) - it is another available HDD in our city and in HCL.
I can't get no
satisfactioninformation about PD feature in original datasheet:https://www.wdc.com/content/dam/wdc/website/downloadable_assets/eng/spec_data_sheet/2879-800074.pdf
Are there many different partnumbers for single WD101KRYZ with different PD options?
Can I use WD101KRYZ with ReadyNAS 214?
Thanks.
Hi vasketsov_serg!
Regards
Thank you very much, Marc_V!
